Losing coolant after full throttle run - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-22-2013, 10:29 PM Thread Starter
Hi Guys,
My son-in-law just picked up an '06 F250 crew cab short bed. I'm helping him with research on issues with the 6.0 Powerstroke. He has had the truck for about a week and called me today because it is pushing out coolant after full throttle acceleration.
The truck is bone stock except for 33" tall tires. When he test drove it he romped on it for a short distance and on returning to the dealer he noticed a puddle of coolant forming. They popped to hood and it was coming from the reservoir cap. They thought someone had probably not tightened the cap properly. He got on it again today and ran it up from 60-90 mph and it puked coolant again from the reservoir cap.
We're concerned it might be a blown head gasket. Any thoughts on most likely causes for this coolant loss?
Thanks,
Lyle
SGLTRK is offline
post #2 of 13 Old 04-22-2013, 10:52 PM
KCCO!!
kells17's Avatar
Could be blown head gaskets, a bad coolant cap on the degas bottle, or too much coolant. The new "full" mark for the 6.0 is the min mark on the degas bottle. If there is too much coolant, it will puke out. Do you know if there has been previous head work done?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 13 Old 04-22-2013, 11:33 PM
Like a boss!
Laferty's Avatar
Headgaskets or egr cooler. How mechanically inclined are you 2?
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #4 of 13 Old 04-22-2013, 11:48 PM
john galt's Avatar
Quoted: 1332 Post(s)
I am pretty new to these but IF he is lucky it could just be a bad cap. or at least that is the case with any of my old trucks
correct me if I am wrong. as I said I am REAL new to these trucks BUT
I assume if it is the head gaskets he will be getting milkshake in his oil.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #5 of 13 Old 04-22-2013, 11:58 PM
KCCO!!
kells17's Avatar
True statement...I remember the OP asking about fuel issues in a different thread and mentioning not having funds to dump into the truck. I'm siding with Laferty, it being gaskets or egr cooler, but could be a simple fix. (We hope)
VA Strokers
757 Diesel
kells17 is offline
post #6 of 13 Old 04-23-2013, 12:00 AM
john galt's Avatar
Kells somehow I completely missed your post...never mind
I like mead
post #7 of 13 Old 04-23-2013, 12:03 AM
john galt's Avatar
from what I have learned on this forum I am GUESSING you are probably right but I am HOPing for an easy fix. I have to I just bought a salvage
I like mead
post #8 of 13 Old 04-23-2013, 12:05 AM
Like a boss!
Laferty's Avatar
That is not a requirement to be bad gaskets. They could be bad in a place that is not allowing cross contamination of fluids. Generally on these engines the headgaskets are proven bad when you do a egr delete and are still puking coolant. The cause is the cylinder pressure is being leaked into the coolant system and causes it to become over pressurized
2006 CCLB
Laferty is offline
post #9 of 13 Old 04-23-2013, 12:10 AM
KCCO!!
kells17's Avatar
Bleh...no worries, CHIVE on!
VA Strokers
757 Diesel
kells17 is offline
post #10 of 13 Old 04-23-2013, 05:50 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1785 Post(s)
Feedback Score: 4 reviews
Don't know if you saw this sticky in the general 6.0 thread, this may help you guys.
Troubleshooting coolant loss (white residue around cooling system components(degas))
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
