Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 02-15-2008, 08:09 PM
smuesse smuesse is offline
EGR/OIL Cooler Coolant Routing
Im just curious. What if i Disconnect the EGR Cooler from the rubber line connecting it to the Oil Cooler. Connect to the oil cooler and route the coolant into a T into a Heater core hose? Would that work or will coolent run back up through the Intake and out the EGR cooler?
Old 02-15-2008, 08:43 PM
mschn99 mschn99 is offline
Banished
bad idea........
the origional cooling system flow needs to be maintained...the cooling system charactarisics of the system are bad enough...we dont need to make them worse...
Old 02-16-2008, 04:16 AM
720Deere 720Deere is offline
It won't work hoss. You have to maintain the coolant flow that comes up from the block thru the intake. If you just cap it off you are deadheading coolant from another spot that needs flow and you will cause a new problem.
Old 02-16-2008, 10:17 AM
Thanks for the advice guys. Im gonna do it the right way. Im taking off the intake.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
