Overdrive Miss and Death Shake! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-21-2013, 05:35 PM Thread Starter
airhead426's Avatar
Send a message via Skype™ to airhead426
Question Overdrive Miss and Death Shake!
2004 F350 6.0l Automatic
It has done this for sometime now, and only between 45 - 75 MPH in the 1800 RPM range when in overdrive and I ease into maybe 5-25% throttle.
Idles fine but has an occasional miss/detonation to it.
When I run WOT the truck acts like it hits a fuel cut in the high RPM range almost if it isn't getting enough fuel or oil to the injectors.
I have not replaced the FPR Spring HPOP ICP Sensor or IPR Valve. It has remanned injectors but throws Cylinder #5 and #8 codes if I remember from the last time I checked.
I replaced the EGR cooler with the delete kit last summer along with the old FICM with a 58v Swamps Hercules tuned by Innovative. I use a DiaBLOsport Programmer on the 100HP tune as my DD. The transmission has been rebuilt twice in the past 30,000 miles under warranty by AAMCO so I know the overdrive is not going out.
Any ideas where to start? Before I throw money at this thing again for the second summer in a row....
Please help! Many Thanks.
Andrew
2004 Ford F350 6.0L CrewCab LongBed 4x4
K&N Intake
Straight Piped
Sinister EGR Delete Kit
Sinister Coolant Filter
Swamps 58v FICM with 100HP Tune
DiabloSport PickUpsPlus Custom 150HP Tune
High Idle Mod
A few extra goodies
WARNING: Tailgating WILL Cause Temporary Blindness
airhead426 is offline
post #2 of 6 Old 04-24-2013, 08:36 AM Thread Starter
airhead426's Avatar
Does anyone have any ideas?
Bump
K&N Intake
Straight Piped
High Idle Mod
A few extra goodies
post #3 of 6 Old 04-24-2013, 08:49 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Bump
Put it back to stock and see if it still does it.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #4 of 6 Old 04-24-2013, 08:51 AM
twildman's Avatar
Quoted: 2 Post(s)
Overdrive miss and shake - YouTube
Andrew
Thats part of your problem. AAMCO can't build a tranny for a diesel.
twildman is offline
post #5 of 6 Old 04-24-2013, 08:57 AM Thread Starter
airhead426's Avatar
It still does it on stock tune almost the exact same as far as speed and level of severity goes, and believe me I know that now I will be going with an ATS in the fall as long as I'm not putting a set of injectors in.
Thanks
K&N Intake
Straight Piped
High Idle Mod
A few extra goodies
post #6 of 6 Old 04-24-2013, 10:53 AM
Gotta start by getting a gauge on there and monitor fuel pressure.
smokejoke is offline
Tags
6.0l , hpop , injectors , miss , shake
