Chugging - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-21-2013, 12:39 PM Thread Starter
Chugging
so i noticed when doing about 40mph if i get on the throttle i have a bad vibration and "chugging" feeling. Boost gauge dont fluctuate it stays steady. To me it feels like a dead cylinder. Im thinking injector not working but i was also told it could be the EGR and/or EGR valve. Im hoping EGR since it will be gone soon anyhow. Theres no lights on in the dash. Any ideas?
powerstrokelover is offline
post #2 of 8 Old 04-21-2013, 12:49 PM
Louiediesel's Avatar
i think if it was you EGR you be blowing smoke ? how bad is it chugging ??
Louiediesel is offline
post #3 of 8 Old 04-21-2013, 05:13 PM
airhead426's Avatar
Send a message via Skype™ to airhead426
my egr cooler failed and I will post the video of my symptoms
2004 6.0 problem child - YouTube
I went ahead and did the egr delete and FICM replacement from Swamps
2004 Ford F350 6.0L CrewCab LongBed 4x4
K&N Intake
Straight Piped
Sinister EGR Delete Kit
Sinister Coolant Filter
Swamps 58v FICM with 100HP Tune
DiabloSport PickUpsPlus Custom 150HP Tune
High Idle Mod
A few extra goodies
WARNING: Tailgating WILL Cause Temporary Blindness
airhead426 is offline
post #4 of 8 Old 04-25-2013, 12:47 PM Thread Starter
you can feel it lose some power and the RPM gauge will go up and down but barely. Id say 150-200RPM. Im wondering maybe injector is dirty? i found some oil in my inner cooler elbow but not much. I had an oil leak around my oil cooler for awhile so im thinking some oil got in and made its way through the intake. That problem is gone now.
post #5 of 8 Old 04-25-2013, 08:06 PM
The oil in the intercooler is normal. The crankcase vent (CCV) is routed into the turbo inlet and the oil goes through to the intercooler and into the intake.
You can do a CCV reroute or dump to minimize (or eliminate) the oil. It will help save the oil from soaking the boots and causing them to fail eventually.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #6 of 8 Old 04-25-2013, 08:31 PM
RedneckYankee's Avatar
Could be an injector. Do you have a way to do a buzz test and contribution test? I had injector 6 lay down on me no codes, no smoke just bucking which was worse while running a tune. Stock tune didn't happen as bad. Tried HSS and switched to Rottella T6 to see it would help and didn't do much good. Finally did a contribution test and you could see it dropping out. Replaced injector and truck was happy again.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #7 of 8 Old 04-25-2013, 08:35 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
it could be the FICM as well.. check the FICM voltage and pull the EGR valve and have a look.. clean it out if necessary
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #8 of 8 Old 04-27-2013, 12:40 PM Thread Starter
Done the CCV already. I think the oil i seen was from before i did it. Ive tested the FICM and is fine. How do i do the contribution test?
