need some imput please going bananas. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-21-2013, 09:18 AM Thread Starter
Louiediesel's Avatar
I have a 05-350-60 in the morning when starts up runs smooth for about 20 miles then gets to missing bad at idle ? barking, backfiring I'm puzzeld by it ...any sugestions i would appreciate it.... No DTCs,no smoke had a new IPR installed 6 months ago
Louiediesel is offline
post #2 of 13 Old 04-21-2013, 09:21 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 839 Post(s)
Feedback Score: 6 reviews
When is the last time you changed your filters? Have you checked your FICM voltage? Do you have any way of checking for codes?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 13 Old 04-21-2013, 09:28 AM Thread Starter
Change filters about a month ago or 500 miles,No codes,checking the ficm shows right at 48 ............did again this morning was running good and I felt the sudden change to missing and jorking ....it seems that is doing it when it gets fully warm up...this sucks
post #4 of 13 Old 04-21-2013, 01:50 PM Thread Starter
could use some thoughts on this......
post #5 of 13 Old 04-21-2013, 02:16 PM
RIP Cam!
Quoted: 839 Post(s)
I wonder if you might be getting some injector siction. Maybe try running some Rev-X oil treatment through it. I use it on my truck and it works great, smooths out the injectors and took away the sputtering I had before.
What oil are you using by the way?
post #6 of 13 Old 04-21-2013, 04:35 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
It sure sounds like an injector problem. However, what is causing it is the question. Is it an injector or the FICM? Remember, your FICM controls the injection sequence. What is your FICM voltage when this is happening? EBP sensor going out? What is the sync doing?
Contribution and balance test is needed warm to help diagnose.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 13 Old 04-21-2013, 04:35 PM Thread Starter
hi yea I run the t6 with revx every other oil change,is acting up when it gets warm/hot so i have something else going on, hard starts after is warm but statrs still.
post #8 of 13 Old 04-21-2013, 04:49 PM
Quoted: 43 Post(s)
I forgot to add, check your wiring to the injectors.
Frank
Working for Toys
post #9 of 13 Old 04-21-2013, 09:11 PM Thread Starter
will check in the morning....and definitly have to clean and or replace the EBP sensor never done it yet so sure needs it.......
post #10 of 13 Old 04-22-2013, 06:15 AM
RIP Cam!
Quoted: 839 Post(s)
If you are having hard starts after it's warm, then you may have a high pressure oil issue. Check the ICP and the IPR. Worse case scenario is that the HPOP is on its way out. I'm not saying that is the case here, just throwing out ideas.
