Going through coolant in like 2 days - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-20-2013, 07:52 AM Thread Starter
southern raised's Avatar
hey i have an 04 with a 03 6.0 motor egr has been deleted and studs have been done. everything checks out fine i plug my diablo tuner in to pull codes and nothing major shows, my truck is on stock setting but goes through a whole thing of coolant in about 2 days but the truck is running fine, and thoughts what this could be? my first thought could be the head gaskets but im not sure anything could help thanks.
southern raised is offline
post #2 of 15 Old 04-20-2013, 08:26 AM
Quoted: 3 Post(s)
degas bottle puking?
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #3 of 15 Old 04-20-2013, 11:00 AM Thread Starter
whats that lol?
post #4 of 15 Old 04-20-2013, 11:17 AM
Snake's Avatar
Quoted: 47 Post(s)
Translated: is the coolant overflow bottle overflowing?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #5 of 15 Old 04-20-2013, 04:23 PM Thread Starter
no its not
post #6 of 15 Old 04-20-2013, 04:29 PM
KCCO!!
kells17's Avatar
See any leaks underneath?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #7 of 15 Old 04-21-2013, 06:50 AM Thread Starter
No, no leaks
Sent from AutoGuide.com App
post #8 of 15 Old 04-21-2013, 06:58 AM
Term3's Avatar
Quoted: 2 Post(s)
What type of delete? Is the cooler still in place but the exhaust side just capped off? If so maybe the rear cap is leaking coolant into the exhaust?
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #9 of 15 Old 04-21-2013, 07:00 AM
Like a boss!
Laferty's Avatar
Originally Posted by southern raised View Post
No, no leaks
Leaking it somewhere... lol. After you park the truck there is no puddle underneath?
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #10 of 15 Old 04-21-2013, 07:04 AM
Term3's Avatar
Quoted: 2 Post(s)
Also check in the engine valley. Perhaps a small leak collecting there slowly then with on road travel it mostly sloshes out and then when you park there's nothing dripping?
Term3 is offline
