coolant leak to oil - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-19-2013, 05:09 PM Thread Starter
burchesss's Avatar
coolant leak to oil
I just bought an 04 6.0 F350 lariet crew 4x4 drw 145k for $6000 it was not running I found it wasnt building oil pressure, loosing oil out a missing freeze plug in the head. Replaced the cooler and did egr deleate primed the oil rail. And it ran great but when i went to flush cooling system it was filling the crank case with water. I looked at the options of cab vs engine. Decided to pull the engine (3.5hrs) the water seems to be coming from the center but i cant see where exactly. Planning on head gaskets and studs what else should I look for any areas prone to cracks?
burchesss is offline
post #2 of 5 Old 04-19-2013, 07:14 PM
thumper280zx's Avatar
check the oil cooler. if they ran it hot then the problem could be there.
06 F350 King Ranch
egr delete, coolant filter, sct tuner more to come soon
thumper280zx is offline
post #3 of 5 Old 04-19-2013, 07:32 PM Thread Starter
burchesss's Avatar
Oil cooler is brand new (assumed good) dont think I cut any gaskets on the install... am I correct to say injector cups would leak to combustion chambers not crank case? It is a fast leak so it may be a cracked head
post #4 of 5 Old 04-20-2013, 04:45 PM Thread Starter
burchesss's Avatar
And I forgot to ask has anyone found the v-band clamps for the turbo aftermarket? My local Napa ordered them twice both wrong both times... hate to go to dealer for the clamps.
post #5 of 5 Old 04-21-2013, 06:05 AM
southend's Avatar
A hole on the front cover behind the water pump is likely.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
