rough idle and low power - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-19-2013, 04:40 PM Thread Starter
bought truck 2 months ago...ran perfect, noticed a couple puffs of white smoke when getting off freeway 2 weeks ago. did not get hot or lose more the half gallon of coolant. replaced egr cooler and did a egr delete. truck started right up after priming but runs rough at idle, has no power until about 2000 rpm, even then has a skip. shows no codes with advance auto parts scanner, went and bought a sgt live wire scanner, still no codes. ficm is good, doesnt lose coolant or oil, no exhaust leaks . ran perfect before , cant figure this out ???
bluebyyou is offline
post #2 of 2 Old 04-20-2013, 06:37 AM
I hope you mean that you replced the oil cooler not the EGR cooler as you also did an EGR delete
Sometimes it take a while to work the air out of the system. Beyond that look at you injector plugs and FICM plugs to be sure you got them all seated right.
Run a power balance when cold and see which cylinder is dropping.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
