Rough idle at stop light - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-19-2013, 11:43 AM Thread Starter
novemberdelta's Avatar
Quoted: 3 Post(s)
Last week I was coming home sitting at a stop light when I felt the truck shake a little. I turned the radio down, looked at the rpm's and they were going up and down like it was missing a little bit. I put it in neutral, gave it a little gas and it came right out of it. I messed with it for a while that night trying to get it to do it again and couldn't. So today after coming out from getting a hair cut I started the truck and it did the same thing very briefly and then went back to normal idle. It didn't seem to crank any longer than normal but I'm wondering if it could be a high pressure oil leak. I watched my scan gauge while cranking and the FICM voltage was 48.5. The battery voltage was a little low, but I'm going to load test them this weekend. I feel like I read something that you could watch on the scan gauge to see if there might be a high pressure oil leak. Any ideas?
2015 F-250 XLT
Fisher 8.5' Extreme V Snow Plow
novemberdelta is offline
post #2 of 11 Old 04-20-2013, 02:17 PM Thread Starter
Quoted: 3 Post(s)
I checked my IPR and ICP. When the engine is hot at an idle the IPR is 19.1 and ICP is 580. Batteries load tested good. Still idling rough every once in a while on a hot start. Hasn't done it at a stop light again though.
2015 F-250 XLT
post #3 of 11 Old 04-21-2013, 09:00 AM
I had the same problem last year on my '04. It got progressively worse until it would stall at stoplights. It ended up being a high pressure oil leak. The shop I took it to needed three tries to find it. Mine ended up being one of the braided lines under the valve cover. The HPOP was replaced the year before so I was fairly sure it wasn't the problem. I wasn't too impressed with the shop I took it to. Normally I would have had a go at it myself but I was too busy with work and really needed the truck ASAP.
tomshane is offline
post #4 of 11 Old 04-21-2013, 09:54 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Start with the easy things first before you jump to a HPO leak...
Might be some bad fuel... Where do you get your fuel from?
Same station or whatever is cheap?
Next, try some Diesel Kleen to clean out the system.
If you still have issues, replace your fuel filters.
If after all that, THEN start looking into other causes, possibly HPO leaks.
Good Luck!
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #5 of 11 Old 04-22-2013, 11:41 AM Thread Starter
Quoted: 3 Post(s)
Yeah, I planned on trying that stuff first. I thought it was just an idle problem to begin with, but today it cut out on my going down the highway on and off for about 10 minutes. I didn't seem to loose any power other than it cutting out and it came out of it after a little bit. I'm going to pick up filters tomorrow and see if that makes any difference.
2015 F-250 XLT
post #6 of 11 Old 04-23-2013, 03:50 AM
dfuzz78's Avatar
Please explain "cutting out."
Was it stalling/shutting off?
Then no-starting hot for about 10 minutes?
Denis "Lt. Sled"
dfuzz78 is offline
post #7 of 11 Old 04-23-2013, 07:42 AM Thread Starter
Quoted: 3 Post(s)
It wasn't stalling, just missing. I got a code for the number 2 injector, so I'm sure that's probably what my problem is. It just started being noticable at an idle. It hot starts fine too.
2015 F-250 XLT
post #8 of 11 Old 04-23-2013, 09:01 AM
dfuzz78's Avatar
Ya, #2 is on it's way out.
You have two choices at this point:
1. Replace the #2 injector... it's fairly simple to replace since #2 is on the driver's side. Ask me how I know...
2. Try to see if it can be fixed with a treatment of Rev-X... this stuff has been known to work wonders!
Denis "Lt. Sled"
dfuzz78 is offline
post #9 of 11 Old 04-23-2013, 12:17 PM Thread Starter
Quoted: 3 Post(s)
I'm doing a service and trying rev x tomorrow. It ran fine today so it couldn't hurt to try. If it acts up againil ill put an injector in it.
2015 F-250 XLT
post #10 of 11 Old 04-26-2013, 07:28 AM Thread Starter
Quoted: 3 Post(s)
So the service didn't seem to help. It started cutting out again and now I have a code for cylinder #8. I talked to a ford mechanic last night that told me If I'm getting both codes he would go ahead and just replace the 4 on that side while I have it apart. Seems kind of pointless to me if the other two are good, but I'm not really sure if they are or not so I may just tear it down and pick up 3 more.
2015 F-250 XLT
