Turbo CAC tube brace!!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-18-2013, 10:37 PM Thread Starter
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Had another CAC hose blow off the turbo while driving on the freeway so I limped the truck back home with very loud turbo whistle and no boost registering on the gauge, this is the third time since the truck was new.
The last time that the hose blew off was over two years ago, I found out that the best way to clean the oil off the hose and flange is to spray with starting fluid (had some in my tool box) and wipe several times with a clean rag. I expected this to hold for a little while, but it ended up holding for over two years!!!
Well now to the brace, I put a new hose on, got to looking at the CAC tube and decided that I didn't want to deal with the hose blowing off in the future and possibly denting my hood, so I picked up a 3" exhaust band clamp and a 3/4" wide piece of flat bar and made a nice bracket to hold the tube secure.
The hose can still tear when it gets old but it can't slide off of the turbo any more!!!
Here is the piece I made to bolt onto the alternator mount:
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #2 of 11 Old 04-19-2013, 12:05 AM
Like a boss!
Laferty's Avatar
Nice idea. Wanna make a few bucks with paypal? lol.
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #3 of 11 Old 04-19-2013, 07:10 AM
Nice work!!! Do you get any weird vibrations or noise with the cac tube being bolted to the alternator?
smokejoke is offline
post #4 of 11 Old 04-19-2013, 07:14 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 896 Post(s)
Feedback Score: 6 reviews
I was wondering the same thing. Also, does it allow the tube to still flex a little with the vibrations from the motor?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #5 of 11 Old 04-19-2013, 08:48 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Good point, under quick throttle there would be some movement. The bottom boot is fairly flexible, but his attachment could act as a fulcrum. His clamp will prevent one problem, but maybe create another. Perhaps another rubber isolator at the alt attachment point would prevent any issues from coming up.
I like his idea, but I wonder what torque he is using on the clamp in the first place.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is online now
post #6 of 11 Old 04-19-2013, 09:15 AM
I seem to remember a few years ago someone selling a similiar contraption on E-bay.
Had a post about it with a link to it. He didn't last here long IIRC
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #7 of 11 Old 04-19-2013, 09:36 AM Thread Starter
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
I just installed it last night so I don't have the answers for whether it needs a rubber isolator of some kind. I can tell you that there are no extra noises or vibrations coming from it.
The biggest thing I will be checking will be the lower boot movement, but the boot is quite flexible and I don't think it will be bothered.
If need be, I could change the clamp to a larger size and add an isolator sleeve to wrap around the CAC tube.
GregsSD is offline
post #8 of 11 Old 04-19-2013, 09:39 AM Thread Starter
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
The clamp is tight on the tube so that there won't be any rubbing through from it vibrating against the tube.
GregsSD is offline
post #9 of 11 Old 04-19-2013, 05:08 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
good idea but not even a little bit necessary
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 11 Old 07-31-2013, 01:04 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 56 Post(s)
Feedback Score: 7 reviews
Would help take stress off the boots from supporting the tube, too.
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
