Stiction Gone - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-18-2013, 12:31 PM Thread Starter
Quoted: 3 Post(s)
Stiction Gone
Well, I pulled my injectors to change the o-rings and seals. While I was in there I pulled out the spool valves and cleaned them. I saw a video on here that promised improvements to stiction after that procedure. Worked like a charm, stiction is gone!
Worth knowing is that a few months ago I put in Archoil AR9100 and it significantly improved my stiction. This solved it!
I was also having a long crank problem, and I updated my standpipes, dummy plugs and STC to try and address the problem. Bummer is I still have the same issue, but at least I did the preventative maintenance!
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #2 of 10 Old 06-03-2013, 06:10 PM
This sounds like what I need to do. I am new owner of this 05 and even here in south tx with 80* mornings, my truck needs 10 min to warm up. I read after the fact that T6 would have been a better oil then straight rotella 15w40 and the previous owner was running T6 as well. The stiction is much worse with fresh 15w40 oil change. Looks like I will be changing back to the pricey T6 and cleaning my injectors, etc...
Thanks for the post, I wanted to try Rev-X or Archoil before getting too involved, but looks like it's inevitable! LOL
TxOutlaw is offline
post #3 of 10 Old 06-03-2013, 11:17 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Glad to see another satisfied owners!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 10 Old 06-04-2013, 06:31 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Awesome!! Need to do mine too, Mines getting bad!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 10 Old 06-04-2013, 07:33 PM
is the long crank problem when its hot or cold?
jpott62 is offline
post #6 of 10 Old 06-04-2013, 09:36 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
Good stuff Iceman.........when the time comes I will do the same instead of doling out money for new ones.
Sean did you run the engine with the valve covers off ?? You gotta have a injector o-ring leaking on and off.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #7 of 10 Old 07-23-2013, 07:02 AM Thread Starter
Quoted: 3 Post(s)
Hey Mark,
I hadn't been checking back and I missed your post. Thanks for looking it over...I didn't run with the valve covers off.
I think I may just have a long crank sometimes. It always fires up, and it seems like I've checked everything
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Zoodad Mod
fuzzman is offline
post #8 of 10 Old 07-23-2013, 09:30 AM
ammohog01's Avatar
This is probably a dumb question but when i had to replace one of my injectors I had the dealer check the rest and they said that #1 and #7 were starting to "leak down" a smidge. Does this sound right? First diesel so I am still learning. Also, when it comes time for the injector change is it pretty easy? I am fairly mech. inclined but for sure no expert.
ammohog01 is offline
post #9 of 10 Old 07-23-2013, 09:58 AM Thread Starter
Quoted: 3 Post(s)
If you are used to wrenching its not too tough. I found a very detailed YouTube video that helped me a ton!
Here is the link
6.0 Liter Ford Powerstroke Injector Replacement, part I - YouTube
Your tech probably performed a leak down test which measures you injectors ability to hold fuel pressure. If they are not holding pressure, you could have one of a few problems. I'm no expert here, so maybe do some homework. Search "leak down test" on the forum and I'm sure you will learn a lot.
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Zoodad Mod
fuzzman is offline
post #10 of 10 Old 07-23-2013, 11:58 AM
Quoted: 46 Post(s)
You should ask them how they did it. If they pressurized the oil rail it is quite possible the seals are weak.
Here is a good video of an 03 with an injector seal problem. Is this what they were referring to?
http://www.youtube.com/watch?feature...&v=mjDUK7ZBK6A
I don't know what other tests are available for a dealer to diagnose an injector other than using the IDS software and a few observation style tests.
Frank
Working for Toys
