Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
  #31 (permalink)
Old 02-14-2008, 07:19 AM
Dirk Dirk is offline
Diesel Innovations
Originally Posted by mountainlander View Post
Not to mention the Ex never leaked until after that repair, then I was getting drips in the driveway. Called on it and he said, and I quote, "Diesels just leak, it's like marking their territory."
Ha.
Ok, go up there and mark your territory. Just don't get caught.
  #32 (permalink)
Old 02-14-2008, 07:25 AM
mountainlander mountainlander is offline
He seemed genuinely surprised to learn they had put the HPOP on, but he looked it up in the computer while I was on the phone with him. When he found it he told me he'd find out what was going on and give me a call back...
I'm going to give them a chance to do the right thing before I get fussy.
  #33 (permalink)
Old 02-14-2008, 07:52 AM
Barchetta Barchetta is offline
Dirty South Stroker
Send a message via AIM to Barchetta
Ha.
I call BS on that. The EPA would have a cow if that we really the case.
Sorry to hear you are going through all this. Even though don't seem like the brightest bunch, they seem to try to make it right.
Good luck and let us know what happens.
  #34 (permalink)
Old 02-14-2008, 05:20 PM
mschn99 mschn99 is offline
diesels do tend to "seep" oil....a drop here...a drop there.....mainly from CAC seepage........BUT no modern motor should leak......that was only acceptable back in the days of cork gaskets...
  #35 (permalink)
Old 02-15-2008, 07:22 AM
Update:
Called the dealership this morning to get the update he promised to call me back with yesterday. Turns out they'll be replacing said gasket at no charge....
Thank you all for your help. The questions you raised helped me paint him into a corner where he had to admit the real problem, and thus that it was their issue to rectify on their dime.
  #36 (permalink)
Old 02-15-2008, 07:30 AM
TXbroker TXbroker is offline
911 is for wussies
Update:
Nice, very Nice
  #37 (permalink)
Old 02-15-2008, 05:09 PM
Glad they are treating you fair!!!
  #38 (permalink)
Old 02-15-2008, 05:21 PM
Yep, can't ask for more.
Won't get it back until the middle of next week though. He said that all the area dealers are sending their diesel work to them because they don't have the techs for it? Anyway, now they have more work than they can do and are running behind.
  #39 (permalink)
Old 02-16-2008, 07:55 AM
So, it just occurred to me, this noise my motor was making could very well have been the HPOP starving for oil since the pan gasket around it was leaking.
Would this have damaged the pump in any way? Should I inist that it be replaced at the same time as they redo the gasket?!?
  #40 (permalink)
Old 02-16-2008, 07:56 AM
no.....the gasket that can leak externally is just a sealing gasket for the crankcase........ although the noise could have been the injectors starving for oil since the oil level was low......
just see how it sounds when you get it back..
