ect low - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-18-2013, 06:04 AM Thread Starter
Krause's Avatar
Feedback Score: 3 reviews
ect low
why does my ect stay so low? would that cause my eot to be high if the t stat is closed not curculating the coolant?
Krause is offline
post #2 of 13 Old 04-18-2013, 06:07 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
What are your temps.?
dhanna6powerstroke is offline
post #3 of 13 Old 04-18-2013, 06:28 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Stuck open t-stat?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 13 Old 04-18-2013, 07:59 AM Thread Starter
Krause's Avatar
my temps are 184ect and 210eot. it very rarely gets to 190ect. i just did headgaskets AGAIN w/studs factory gaskets new oil cooler 10000 miles ago. this is the second or third t stat in a year if that is the problem. what does everyone think?
Krause is offline
post #5 of 13 Old 04-18-2013, 08:09 AM
Mod Newbie
Quoted: 19 Post(s)
The ECT isn't that bad. Mine runs 184-186 all the time with an EOT of 187-191. Sucks to say, but sounds like your oil cooler is restricted again. Have you flushed the cooling system completely at any point?
post #6 of 13 Old 04-18-2013, 08:13 AM Thread Starter
Krause's Avatar
yes, i have flushed the cooling system 3 times the last with restore. also installed diy coolant filter this last hg job. my block seams to make alot of rust. i was hoping the filter would have caught most of it but not quiet i guess. does anyone have any better ways to filter the coolant before it goes into the oil cooler?
Krause is offline
post #7 of 13 Old 04-18-2013, 08:21 AM
Mod Newbie
Quoted: 19 Post(s)
Using the restore is most likely what caused the cooler to get restricted. Some guys use it with no issues and some use it and have to replace the oil cooler shortly after.
post #8 of 13 Old 04-18-2013, 08:22 AM Thread Starter
Krause's Avatar
i did the resore then replaced the hg's and oil cooler. that happens when they dont replace the oil cooler after a flush?
Krause is offline
post #9 of 13 Old 04-18-2013, 08:24 AM
Mod Newbie
Quoted: 19 Post(s)
There's sometimes still enough junk in the system to plug a new oil cooler. I've done it myself.
post #10 of 13 Old 04-18-2013, 09:14 AM
No offense but personally I think both of ya need a new thermostat.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
