Sudden problems: slightly rough idle, no power, low boost, codes - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-17-2013, 10:56 AM Thread Starter
Starts up instantly, wants to run and drive, but has no balls.
Truck ran great this morning. On the way to lunch, pulled out of the parking lot fine, but went down on power on the road. U-turned around and pulled the following codes from the Edge CTS:
P0266, cyl 2 contribution
P0272, cyl 4 contribution
P0401, insufficient egr flow
P0603, ICM KAM error
P0683, Glow Plug Control Module Fault
P132B, Turbocharger Boost Control A Performance
The CEL is not illuminated.
I've never had a code before today.
Rough idle (slightly rough), low power, only 7 psi boost
I don't see anywhere the exhaust is leaking.
Turbo "cycles" at idle. I can hear it while I watch VGT% cycle on the Edge CTS.
Boost pipes pass a visual inspection and a tug test. Not scientific, but the appear fine.
OE Turbo and 8 injectors are almost new. Failed due to lack of use, previous owner drove truck only a couple thousand miles over 2 years.
Rotella T6 oil and Ford oil filter less than a month ago. Oil is full. Added 16oz Archoil 9100 with oil change.
According to CTS, FICM voltage 47V+
ICP ~650 idle. I saw over 3500+ psi this morning when I romped on it a bit.
EGR valve removed, inspected, cleaned 2 weeks ago.
Fuel pump is audible key on, engine off. Doesn't sound super loud to me, but I can hear it. I work on race cars with big Aeromotive pumps, it's not that loud. Need to put a pressure gauge on it still. Both fuel filters replaced last month when I did the oil.
Batteries disconnected last weekend--replaced one of the batteries, though the old battery was still good.
My other F250 is also currently down, had to order an alternator. I'm in trouble. Please help!
berusch is offline
post #2 of 18 Old 04-18-2013, 01:41 PM Thread Starter
Looking at Edge CTS today, key on engine off:
MAP 13 psi
Baro 14.2 psi
IAT: 57
All other fluid temps 77
I understand there are (2) IAT sensors, not sure which the CTS is reporting, but it seems wrong.
Also map and baro do not match.
Everything else looks good:
FICM 47.5V
Battery 12.XV
Pedal position reports 0-100%
MAF appears to be working
berusch is offline
post #3 of 18 Old 04-19-2013, 03:51 AM Thread Starter
Talking to myself I guess, but maybe when/if I get it sorted and post results I can help someone else one day.
Started truck yesterday after it was sitting for a couple days. The MAP reading went to 14psi when I applied a little throttle. I would still expect to see 14 psi key on engine off.
I cleared the codes, and took it around the block. Truck wanted to make lots of boost and drove great. I pulled out of the throttle at 17 psi, no problem.
Truck sat for an hour, went to drive it home, back down to 7 psi again. Parked it.
berusch is offline
post #4 of 18 Old 04-19-2013, 06:49 AM
Your contribution codes could be a FICM issue. Did you check the FICM voltage when it is stone cold at KOEO, cranking and idle? Must be 46+ at all three points.
Your boost issue could be a sticky turbo, sticky EGR valve or other sensor (MAP, EBP, etc...) Did you check the condition of the sensors connectors, pull the sensors and make sure the tubes are clear, etc...?
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #5 of 18 Old 04-20-2013, 04:25 AM Thread Starter
The EDGE CTS reports FICM voltage 47-48V at all times. I have not verified with a multimeter.
Have not done any further diagnosis.
I do not believe it has a stuck turbo -- it's only a few months old and I can hear it cycle at idle. The exhaust note changes dramatically when I see VGT% change on the monitor.
I will look for the MAP sensor, I think I saw one by the pass fender, next to a vac pump.
I pulled the EGR valve 2 weeks ago to clean it. Hit it with a little carb cleaner and wiped it down. It looks like a stepper valve -- If so, I actually have the ability to test a stepper on a bench.
Thank you for your help.
berusch is offline
post #6 of 18 Old 04-20-2013, 07:30 AM
gotta be careful with the carb cleaner, don't get any inside the valve. Also be careful to remove the O-rings before carb cleaner otherwise they swell, get screwed up, etc... You sound pretty dialed in, so I assume you took them off first, but just in case...
MikeB
PSDMikeB is offline
post #7 of 18 Old 04-21-2013, 08:18 AM Thread Starter
I was careful when cleaning the EGR valve.
I suppose I should be able to measure resistance across the "dead" injectors' coils, and if it doesn't appear to be shorted, then scope the high current signal from FICM to see if I have lack of injector command.
berusch is offline
post #8 of 18 Old 04-29-2013, 03:23 PM Thread Starter
Replaced FICM. Low power, low boost, #4 contribution code.
berusch is offline
post #9 of 18 Old 04-29-2013, 05:28 PM Thread Starter
Cleared codes.
Came back with P0276, cyl 6 injector low. No other contribution codes.
Ready to shoot it. Going to try FICM to injector harness.
berusch is offline
post #10 of 18 Old 05-01-2013, 06:05 PM Thread Starter
Got new injector harness from the dealer. When removing the old harness I found that the old harness was missing half its injector retention clips, including on cyl 6 where I was getting the injector low code.
Truck just had 8 injectors installed a few months ago at a diesel shop. The injector plug on 6 had a bent pin. I think they couldn't get it to positively retain, so they just jammed the sucker home and threw the clip out.
I considered cutting the injector's pigtail and weatherpacking it to the main injector harness. I have no qualms with cutting the old harness, but I didn't want to cut up the new one. So I'll get a new injector on order.
The shop had also installed a new turbo, and with the degas bottle removed to access the FICM for harness isntallation, my exhaust leak was obviously located at the up pipe to turbo v-band clamp.
Since there was easy access with the charge tubes out, I went ahead and rebuilt the fuel pressure regulator with the blue spring. The spring that came out was a bronze color, so I assume it was the original.
berusch is offline
