new injectors same problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-16-2013, 08:26 PM Thread Starter
i got a 2004 6.0 7 or 8 months ago i had to replace the injector on # 6 well it went out again the other day so i replaced it and its still the same i think its code 278 i dont think its the injector what do you think it could be i'm tired of tired of tearing down that left side . although i'm getting pretty quick at but i have had enough of it any suggestions
rawdiesel is offline
post #2 of 6 Old 04-16-2013, 08:32 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1658 Post(s)
I cant give you a awnser...I am chasing a cyl2 code. I have swapped 2 good injectors into that hole and still get a cyl2 fault after it gets warm. New FICM harness and rebuilt FICM and still a cyl2 code. If you figure yours out let me know.
toren302 is offline
post #3 of 6 Old 04-16-2013, 11:09 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Is it a contribution code? If so it could be many things, cracked piston, bent push rod(s), bent or broken valve, bad cylinder scoring, worn rings, hole in valve or piston etc.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 6 Old 04-17-2013, 04:17 AM Thread Starter
yes mine is a contribution code
post #5 of 6 Old 04-17-2013, 07:33 AM
Bump To Pass!!
toren302's Avatar
Mine is a cotribution code as well. Compression is good hot and cold and mine only happens when warm.
Sent from AutoGuide.com App
toren302 is offline
post #6 of 6 Old 04-18-2013, 06:03 AM Thread Starter
no compression on #6 you can take a blower and blown air in the cylinder and it comes out the turbo. thats not good i guess we know what this means.cab is coming off.
