NEED TECH HELP! - Ford Powerstroke Diesel Forum
Old 02-11-2008, 02:49 PM
Send a message via AIM to rednek01 Send a message via Yahoo to rednek01
MY TRUCK IS STUCK AT WORK!!!!
Ok guys I will try to make this detailed and short.
My truck usually starts and runs fine. Every once in a while it will stutter at stop lights but takes off fine (both stock and with programs) Friday I came home from work and it ran fine spent about an hour doing stuff at the house then went out to start my truck. Well it will crank over and sounds like it wants to start but wont. later that night I come home from being out and figure I will try to start it and boom it starts right up. The next day I put probably 100 or so mines on it both taking it easy and getting on it both stock and programmed and stopped and started it about 10 times. sunday it worked fine and now monday I'm stuck at work cause it wont start again of all places
I get oil pressure (oil level is fine) but when cranking the rpm's dont move (CPS maybe?) no water in fuel light fuel is fine. I talked to Marc and he thinks it's something electrical. I think it is a sensor but I dont know where to look. Its not under warranty and I really dont want to go to the dealership to get it tested (cant afford to). Can anybody give me some more insight or some tests to run or look at?
thanks
Michael
713-269-7034
Old 02-11-2008, 04:22 PM
bump bump bump in the night
Old 02-11-2008, 04:24 PM
Hope someone chimes in... Here is a bump for you.
Old 02-11-2008, 04:31 PM
If it aint a CAT itsa DOG
Not real sure bud. I know the injection control pressure sensors are prone to goign out on them. They can cause a surging at a light or going down the road. Not sure if it would make the truck stutter though. Sounds kinda like a strange problem. Well heres a bump for ya! Good luck.
Old 02-11-2008, 06:01 PM
yea thats what it is a surging thats a better word for it.
Old 02-12-2008, 04:31 AM
Well I'm thinking it is a Sensor either the CPS or the crank sensor
Old 02-12-2008, 08:10 AM
Old 02-12-2008, 09:04 AM
Well I just ordered the Autoenginunity scanner with the ford specific package I hope this will let me diagnose my problem will it guys?
Old 02-12-2008, 12:50 PM
Anybody have any input?
Old 02-12-2008, 01:17 PM
Are you leaking any oil in the back of your engine by chance? I only ask cause i think the ICP sensor will leak oil when they are going out too. You might want to check that one.
