Low boost- p006a ??? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-16-2013, 04:33 PM Thread Starter
black03's Avatar
As title says low boost highest ice seen is 12 with my MTW hybrid from Adrian trucks is throwing that code could that be the problem
2003 F350 PSD 6.0, Airlift Airbags front and rear. custom 4 inch-5inch exhaust. zoodad mod, ARP head studs, EGR delete, PMM Titanium head gaskets, MAD turbo werks hybrid, more to come
black03 is offline
post #2 of 10 Old 04-16-2013, 09:28 PM Thread Starter
black03's Avatar
Bump.... the code says its a map sensor/airflow
black03 is offline
post #3 of 10 Old 04-16-2013, 09:57 PM
thumper280zx's Avatar
I know I had the same code and boost problem and it just ended up the sensor on the turbo wasn't plugged in. I had to use my sct tuner to turn the code off too
Sent from AutoGuide.com App
06 F350 King Ranch
egr delete, coolant filter, sct tuner more to come soon
thumper280zx is offline
post #4 of 10 Old 04-17-2013, 03:46 AM Thread Starter
black03's Avatar
That's the problem though is that my plug is in.
black03 is offline
post #5 of 10 Old 04-17-2013, 03:48 AM
Colin7.3's Avatar
Exhaust leaks?
Did you have low boost before?
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #6 of 10 Old 04-17-2013, 04:05 AM Thread Starter
black03's Avatar
No and no, I just didstuds and gaskets and everything got buttoned up correctly
black03 is offline
post #7 of 10 Old 04-17-2013, 04:06 AM Thread Starter
black03's Avatar
I just did studs and head gaskets, and no I didn't have low boost before, I've looked for leaks, crawled under there with a flash light and had my wife stomp on the throttle and I didnt see any leaks and couldn't hear any either
black03 is offline
post #8 of 10 Old 04-18-2013, 02:55 PM
Quoted: 3 Post(s)
Is your turbo spinning freely? Pull your intake and check out the turbine wheel....
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #9 of 10 Old 04-18-2013, 02:58 PM Thread Starter
black03's Avatar
I will do that next, it idles normally though
black03 is offline
post #10 of 10 Old 04-20-2013, 02:44 PM Thread Starter
black03's Avatar
Got it map tube was cracked under the clamp
black03 is offline
