Repairing 6.0 w/ 220k mi and no coolant. EGR Delete? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-16-2013, 02:43 PM Thread Starter
A friend of a friend brought me his 2003 f-350 with the 6.0 in it. He says that a previous mechanic said his EGR cooler has a small leak. This was a few years ago. He has been running water only in the cooling system for a VERY long time. It pretty much looks like Tang in the degas bottle. I feel hes going to have a bad day once we get into this thing.
He says hes loosing about 1/2 a gallon a day, no leaks on the ground, and no signs of water in the oil. He wants to delete the EGR cooler. I feel that a serious flush with Restore and Restore+ is in order as well as a new oil cooler and thermostat. All in addition of the EGR cooler delete. I have never worked on a 6.0. But I have done an EGR/DPFE delete on a 6.4. So I have faith I could knock this out.
What else should I look for since the cooling system has been neglected? What commonly fails besides the oil and EGR coolers? I plan to check the EOT and ECT readings to see if something is way off. Also, do I need to purchase a tuner in order to complete the EGR delete? I have read that you need one, as well as you can leave the removed EGR valve connected and get away with it. Confirmation?
Many thanks in advance.
95ImpySS is offline
post #2 of 12 Old 04-16-2013, 02:58 PM Thread Starter
Also. I see just cooler deletes as well as EGR valve and EGR cooler deletes. I would recommend deleting both, but cost is a big issue. What do you guys/gals recommend?
95ImpySS is offline
post #3 of 12 Old 04-20-2013, 02:16 PM
Int.Tech04's Avatar
EGR Delete with Valve blockoff plate from Xtreme Diesel Performance will run $200.
DEFINATELY do a flush. i wouldnt dare dive in for this and not flush it first. if hes been doing nothing but water (smack him real hard in the back of the head ), theres a good chance his Oil Cooler is FUBAR. if you're gonna be in there for the EGR delete, may as well do the oil cooler too. a stock oil cooler with all gaskets from Xtreme Diesel will run $315. since its an 03, you dont have to worry about a check engine light from the EGR valve being removed.
hope ive been of some help.
-Tyler- -Navistar Technician-
2004 F250 CCSB FX4 6.0 - XDP EGR delete, BPD Oil Cooler Relocation, SCT Livewire TS, 315/75/16 Falken Wildpeak A/T's, Rough Country 4in, stock DP with 4in straight pipe.
Int.Tech04 is offline
post #4 of 12 Old 04-22-2013, 07:02 AM Thread Starter
Big THANKS for the reply. I believe I made the right decision. After watching some videos on how much work it is to get to the oil cooler, I decided that it must be changed wile were in there. I ended up with the sinister diesel kit which includes the oil cooler, seals and gaskets as well as the replacement stainless mesh screen. I'm also glad to hear that keeping the EGR valve in will keep the SES light from coming on. Soon as I popped the hood and saw the degas tank, I knew I was in for a job.
I skipped out on the purchase of Restore. I figured that there is no more coolant in this thing and a hefty dosing of Restore Plus is in order.
Planning on knocking it out this weekend. I'll keep the forum updated on how it goes.
95ImpySS is offline
post #5 of 12 Old 04-22-2013, 07:04 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
maybe toss an ipr coolant filter on it too cause it filters way faster than your average coolant filter. so you can race to get it clean.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #6 of 12 Old 04-22-2013, 07:21 AM
Int.Tech04's Avatar
Being an 03, you can just remove the EGR valve and put a block off plate. If it was 05 or newer you would have to have a programmer to shut the EGR off and keep the check engine light off.
post #7 of 12 Old 04-22-2013, 07:53 AM
Therabbittree's Avatar
if its eating coolant or water in his case wouldn't the head gaskets be bad too?
Therabbittree is offline
post #8 of 12 Old 04-22-2013, 08:53 AM
Int.Tech04's Avatar
Not necessarily. If the EGR cooler is leaking, it could just be burning it off. Head gaskets would be the next thing to check once everything is up to par.
post #9 of 12 Old 04-22-2013, 08:55 AM
Quoted: 3 Post(s)
I'd run it for a while with a coolant filter after the flush. Otherwise, you are likely to clog up your new oil cooler with the stuff you broke loose...
Ask me how I know
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #10 of 12 Old 04-22-2013, 09:05 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
i'd do as recommended.. considering there isn't any sign of water in the oil or anything thats good.. i'm hoping the HGs aren't bad but if they are get the heads pressure tested and decked by a reliable company or get new heads.. this could get pricey! does he have a monitor on the truck? if not he should get one just so he's ok in the future.. update the coolant cap.. and try getting a 15PSI pressure gauge and plumb it into the cooling system and see if the pressure goes up past 15 quickly after you get the egr cooler delete in
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
