ECT/EOT Temps - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-16-2013, 03:36 AM Thread Starter
ECT/EOT Temps
I have been monitoring my ECT and EOT's. The ECT is 190 (New Motorcraft Thermostat) EOT is running up to 232. I back flushed my oil cooler this weekend and could get water through it but temps are still way off. I have a new oil cooler etc. ready to install but I just don't know why the oil temp wont come done since I have what I believe is a clear passage through my oil cooler. any comments would be appreciated. I assume its time to change oil cooler.
Thanks
bfordu is offline
post #2 of 7 Old 04-16-2013, 04:45 AM
gotta_gofast's Avatar
Quoted: 61 Post(s)
...Still time to change your cooler. If running water through your bad cooler fixed the problem guys wouldn't be purchasing new coolers. The snot-like silicates and grit coat those passages preventing heat transfer.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #3 of 7 Old 04-16-2013, 05:34 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
Oil cooler is most likely plugged. Check ECT and EOT temps after engine cools off overnight. They should be the same before you start the truck, if they are the same your oil cooler is plugged. Don't wait to long because the reduced coolant flow through it will cause higher egr cooler temps and can cause it to burst.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 7 Old 04-16-2013, 06:01 AM Thread Starter
Thanks, I guess I will start getting into it tomorrow
bfordu is offline
post #5 of 7 Old 04-24-2013, 12:50 PM
casper_8303's Avatar
Garage
What was the outcome? Sounds like my issue.
casper_8303 is offline
post #6 of 7 Old 04-24-2013, 04:12 PM
drivininidaho's Avatar
Quoted: 81 Post(s)
mine is kinda opposite, both of mine stay on the cool side.
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #7 of 7 Old 04-24-2013, 05:09 PM
dxusmc's Avatar
Mine stay on the cool side too, even running my performance tune I never seem to go above 288* for both EOT and ECT. I don't find that to be a problem at all though, somehow I feel I got lucky and my coolers are going back, but then again I get the Diesel Emissions cleaning every 2 years where it just burns out the soot and such.
Unfortunately all of my problems evolve around my FICM and most recently..my oil pressure not reading properly. Still major issues, but at least I can count on my coolers to last a bit longer
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
