Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
  #11 (permalink)
Old 02-21-2008, 02:35 PM
lonestarcj7 lonestarcj7 is offline
Ok, I towed again this week and the problem continues.
I installed my overhead gauges which includes a boost gauge. When the truck is pulling a load up a slight grade, at 70 mph and 2K RPM, the boost will suddenly drop from 25psi to 15psi. The truck quickly recovers but right when it hits the same senerio, it will do it again. I can throddle through it or slow down and the problem dissapears. But it is obviously somthing in the boost. I can hear the air "blow" or escape.
2005 6.0 - 4" Turbo Back Exhaust - Stock
Any suggestions?
