6.0 rattle noise ?? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 04-14-2013, 04:57 PM Thread Starter
6.0 rattle noise ??
I have a 2006 6.0 with about 60000 mi on it. Started to notice a rattle like noise at low speeds.
When you let off the gas a rattle noise is heard and when you start to accelarate it rattles then goes away. And only when hot but not all the time.
Was told might be the turbo was dirty, remove turbo and cleaned it but it wasn't bad at all, end play in shaft felt tight, checked vertical movement there was some but manuel says that was okay as long as ther was no contact while spinning it.
Could this be the valve on he turbo or Injector going bad?
Anyone run into this noise?
davisot is offline
post #2 of 23 Old 04-14-2013, 05:56 PM
make a video and post it on you tube
smokejoke is offline
post #3 of 23 Old 04-15-2013, 05:27 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 444 Post(s)
Garage
You sure the exhaust is not rubbing anywhere.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 23 Old 04-15-2013, 08:21 AM Thread Starter
I removed the the down pipe, thinking that it was rubbing,checked and tighten the rest of the exhaust.
The noise almost sounds like a duck quacking, doesn't do it at idle or when reving in the drive way.
davisot is offline
post #5 of 23 Old 03-03-2014, 05:50 PM
figure out what it was? I have a similar noise.
tony0713 is offline
post #6 of 23 Old 03-04-2014, 05:22 AM
could be a charge air leak. Check intake tubes for cracks and hot side rubber hoses for wear and clamps for tightness and overall condition. Could also be the intercooler cracked or damaged.
What you are describing sounds air related, so focus there. Since it only happens when up to operating temps it could be an exhaust leak, which would take a little digging to find, so start with intake side first.
Bodywerks0660 is offline
post #7 of 23 Old 03-05-2014, 02:14 PM
this is what I'm talking about. and it goes away as you coast when the PCM shuts the injectors off.
http://s305.photobucket.com/user/tse...67d32.mp4.html
kind of sounds like it's coming from the egr but it's really hard to tell. so I unplugged it and it still made the same noise.
tony0713 is offline
post #8 of 23 Old 03-05-2014, 02:38 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
check all the cylinder ports where the exhaust manifold mates to the heads. its got a little whistle to it like an air leak.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #9 of 23 Old 03-05-2014, 05:56 PM
yea the 2nd cylinder from the back has a slight leak. but that doesn't explain the noise from up front
tony0713 is offline
post #10 of 23 Old 03-06-2014, 09:33 AM
any know have any ideas. it's worse when the motor is warmed up.
tony0713 is offline
