05 6.0 wont start - Ford Powerstroke Diesel Forum
Old 02-09-2008, 06:28 PM
05 6.0 wont start
my o5 acts like it has a mind of its own. most of the time it starts just fine but other times it just turns over. its runs completly fine other wise. ive taken it to the dealership 3 times and they say that there is nothin wrong with it.
PLEASE HELP!!!!!!
Old 02-09-2008, 06:31 PM
HPOP leak????
Techs????
When it just turns over is it cold or warm?
When was the last time you changed the fuel filters?
Edit: Yeesh Paul, that's twice in the last two minutes!!!
Old 02-09-2008, 06:33 PM
Edit: Yeesh Paul, that's twice in the last two minutes!!![/QUOTE]
huh?????????????
Old 02-09-2008, 06:34 PM
huh?????????????
That I've posted on a thread with the same thought as you and you beat me to the punch. LOL.
Old 02-09-2008, 08:06 PM
mostly when its warm when it does it, but sometimes it will have a long start when its cold. what exaclty is the HPOP? and why couldnt the dealership find a problem?
Old 02-09-2008, 08:23 PM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
HPOP is high pressure oil pump and needs to be full and creating pressure to run your injectors.
that all the help i am except for this
Old 02-09-2008, 08:26 PM
so im guessin thats if its the problem its not goin to b cheap. and what could cause this problem?
Old 02-09-2008, 08:35 PM
There are little rubber o-rings that seal everything up...as they go bad, when your motor is warm and everything expands the pump won't hold pressure. And since it's oil pressure that drives the injectors....
And yes, it ain't cheap.
Old 02-09-2008, 09:28 PM
if its an icp prob most likely itll be a d ring or stc fitting that connects the branch tube to the hpop. very very common!
