HELP, blue spring low FP - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-14-2013, 10:29 AM Thread Starter
I have an 03 6.0 and was getting 50psi at idle, ~42psi WOT. So I put in the blue sring upgrade. At first it gave me 58-59 at idle and 50 WOT. Its been a few days now and and Idle psi has settled at 55. At seemingly random times, driving or idle, fuel pressure will drop sharply as low as 39psi for a few seconds before returning to normal. Ive looked it over and see no signs of fuel leeks around the fuel pressure regulator. Can you guys help me out on this?
aeby07 is offline
post #2 of 20 Old 04-14-2013, 01:09 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Gauge, pump or?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 20 Old 04-14-2013, 01:38 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
How old are the fuel filters ??
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 20 Old 04-14-2013, 01:52 PM Thread Starter
Im getting the readings from the fuel pressure test port in the pressure regulator housing via my edge CTS. the fuel filters are only 4,000 miles/ 6 months old
aeby07 is offline
post #5 of 20 Old 04-14-2013, 02:29 PM
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
You may need a new fuel pump. Not sure if your year tank has the filters in it but that is a possibilty.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #6 of 20 Old 04-14-2013, 03:24 PM Thread Starter
I does have a filter in it, It seams like its got something to do with the blue spring upgrade, the sharp drops at least. I havnt seen it drop so low so fast before I put it in....
aeby07 is offline
post #7 of 20 Old 04-14-2013, 07:04 PM
Quoted: 47 Post(s)
You may have to check that all the pieces are installed and in good shape.
FWIW, I had a bad (short) blue spring. It was slightly shorter than my stock one I removed. When I started it up, I was 10 psi lower than the stock one. I stretched the stock one and put it back in while I waited for the new one to show up. I also ordered a $15 similar one off eBay. It runs at 80psi, just 6 above my new blue one, but less than 1/2 the price.
As well, after all the BS with this, I just removed the 4 cap screws and left everything else hooked up to swap out the springs. I just removed the CAC at the intake to make it easier to get at the screws.
Frank
Working for Toys
post #8 of 20 Old 04-14-2013, 07:12 PM
sprksonu's Avatar
80 PSI??? holy crap
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #9 of 20 Old 04-15-2013, 06:59 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
I thought anything over 75 PSI puts you in danger of blowing injector o-rings. Dont remember where I heard that, but correct me if I'm wrong. Are you still running this 80 PSI spring?
To the OP, you possibly have a weak pump, something is clogging the pick-up, or your pick-up is sucking air. Whats the fuel level in the tank when you notice the sudden drops in pressure?
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #10 of 20 Old 04-15-2013, 07:40 AM Thread Starter
You know I thought about that today, Im just below a quarter tank and I dont usually let it get that low. Im going to fill up later today and see if that helps
aeby07 is offline
Tags
blue spring , erratic fuel pressure , fuel pressure , low fuel pressure
