Exhaust leak (up pipe) - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-13-2013, 05:38 PM Thread Starter
Hi there, got a f350 6.0 that I had the egr delete studs etc put on it, I started it up today and there is the worst sounding whistle coming from the truck I thought it was the turbo that is bad but I took the boot off the intake and felt the turbine and it's fine I then tracked the sound to the exhaust passenger side the pipe that connects to the manifold then up to the turbo area, the flex point here is split and letting a lot of air out and making a horrible noise.
see the attached photo below showing the part.
Uploaded with ImageShack.us
My question is what would be the solution to this problem, Do I just need the stainless UP pipe or do I need to replace the whole y pipe how common is it just for one of the flex to split. I need to pull the turbo anyway to clean so I will fit the new part while the turbo is off. I was thinking of just getting the stainless UP pipe and then hopefully this will solve the problem, but I want it to be resolved and not have an ongoing issue.
Any help will be great
Cheers Phil
Phi1 is offline
post #2 of 7 Old 04-14-2013, 04:34 AM Thread Starter
anybody able to suggest anything?
Phi1 is offline
post #3 of 7 Old 04-14-2013, 05:59 AM
Since you are removing the turbo for cleaning it will make this repair easier. You do not have to replace the complete Y pipe unless you wanted to. Since your EGR is deleted you only have to replace the bellow with a straight pipe. I just got done replacing the up pipe on mine due to a crack in the bellows. I chose to replace it with a stock up pipe and close off the flange to the egr cooler.
jeephauler is offline
post #4 of 7 Old 04-14-2013, 10:09 AM Thread Starter
Yeah I ordered the solid UP pipe so will have the turbo off and fit that clean the turbo while it's off as it's sticking vgt at the moment, I also have my mbrp 4 inch system waiting to get fitted at the same time!
Phi1 is offline
post #5 of 7 Old 04-14-2013, 12:24 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It is a common problem, sounds like you have it figured out!
I also have a leak at the same spot and am going to change mine out with an aftermarket one.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #6 of 7 Old 05-03-2013, 03:57 AM Thread Starter
Well I replaced it the bolts to the Y pipe were seized so I had to grind them off but it's all replaced now and no more squeaking!
Phi1 is offline
post #7 of 7 Old 05-03-2013, 04:25 AM
Quoted: 2 Post(s)
Good deal. Did the same thing on mine but lucked out on the bolts, mine came right off with no problems at all lol
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
