2004 f350 internal engine damage! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-13-2013, 07:19 AM Thread Starter
proudfordowner's Avatar
I have my 04 in at the dealer right know as we speak for erratic idle and blowing blue/white smoke.. I thought it was injector, but tech diagnose low compression on number 4 cylinder and advised for the head to be pulled for further view.. Head was pulled and found piston contacted intake valve and bent the valve. The valve face and seat as score marks but no debris left, cylinder walls look fine . Tech thinks foreign object held valve open.. The turbo has no marks at all so it as to be from after the turbo.. Intake manifold was taken off year and a half ago for egr delete and oil cooler replaced.. Has never been off since.. Doubt any debris would hang around for that long then year and a half later cause issues.. Cylinder walls are fine so prolly not a broken piston ring... Injector tip looks fine, glow plug looks fine... Any ideas? My truck has the ford esp powertrain warranty btw.. Ford better cover it! I need some input.. Thanks guys
Sent from AutoGuide.com App
2004 f350 SUPERCREW
-zoodad mod, high idle
-edge insight w/egt, digital fuel pressure gauge
- upgraded fuel regulator spring
- back auxiliary lights
- swamps 58v ficm
-dieselsite coolant filter with zerex elc
- SCT x2 tuned by matt @gearhead
- dicad solutions EGR delete
- new oil cooler..
If you can't stand behind our troops, try and stand in front of them...
proudfordowner is offline
post #2 of 7 Old 04-13-2013, 03:29 PM Thread Starter
Anybody?
2004 f350 SUPERCREW
- swamps 58v ficm
- new oil cooler..
post #3 of 7 Old 04-13-2013, 03:48 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
I don't know what you're looking for, you have a bent valve. The question is what caused the problem. Without a part or a crystal ball, any guess is a good guess. It could have even been a piece of carbon goo from the intake that broke loose, or perhaps you have a bad bearing that is letting the piston move to far up the cylinder.
twoicebergs is offline
post #4 of 7 Old 04-13-2013, 04:01 PM Thread Starter
I am just trying to gather ideas on how it happened.. Ford is sending an inspector out.. I really hope this is covered under my warranty.. If they can't figure out the cause does anybody know if ford will still cover it under warranty? The carbon theory is possible..
2004 f350 SUPERCREW
- swamps 58v ficm
- new oil cooler..
post #5 of 7 Old 04-14-2013, 08:51 PM
Have the same issue but cyl 6...what did the dealer give you as an option?
Capt Trashy is offline
post #6 of 7 Old 04-15-2013, 08:03 PM
kdogg85's Avatar
You understand that due to the egr being AWOL, you probably will not be covered. Big no no if a warranty is still active.
That out of the way, a rocker could be slightly bent, bad bearing, or a piece of metal broke loose from the intercooler and found the valve. The carbon thing, I would highly doubt, it would almost have to be a diamond to really do much.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #7 of 7 Old 04-15-2013, 08:19 PM
sprksonu's Avatar
I was about to say the same thing no EGR = no WARRANTY but I could be wrong??
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
