Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 02-08-2008, 08:56 AM
44Junior44 44Junior44 is offline
Warranty Question - My Story
03 6.0, not modified at all. No issues with the truck at all with over 84k miles. One day it just wont start. No issues prior to problem, no leaks that I can see anywhere, power is normal etc. It just wont start. The dealer claims that while not the problem they notice air filter is clogged (changed April of 07) and the fuel filter is so bad that it has partially collapsed. They ask for service records and get them. Lots of oil changes and air filter replacements but serious lack of fuel filter changes only three since owned and in fact none since 32k miles. Based upon this, they deny warranty work on engine. I ask them what the problem is with the engine. They have not done enought work to determine that they say but based upon lack of mtnce records, they say no warranty coverage regardless. They then proceed to determine that the EGR cooler and valve need replacing along with the removal and cleaning of carbon from the intake manifold. The cost of this is estimated to be $2,400 BUT, once they get it going then they will determine if injectors are needed which will increase the cost. The guy also states that the motor was partially hydro-locked. I find this hard to believe since it cranked over OK.
Regardless here is my question....how can they deny warranty coverage prior to determining what is wrong? I admit I lacked on the mtnce but did the clogged fuel filter cause the problem? How could it have run so well and without a check engine light then die with such major work necessary?
The only symptom we noticed prior to non-start was the smell of hot oil after we parked it and walked around the front grill. I looked everywhere but could find nothing leaking.
Thanks for any info you guys can provide.
Junior
Old 02-08-2008, 09:03 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
it is possiblw to hydrolock engine even after you turned it over , coolant ca run into the cylinders if egr is bad enough , need to find out warranty start date , if its in on time and mileage i would have to get a little irrate with them, it does sound like thay may be trying to pull one on ya
Old 02-08-2008, 11:06 AM
Rob Rob is online now
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
they just dont want to warranty it. they want customer pay since it is more pay.
Old 02-08-2008, 11:13 AM
4everlearning 4everlearning is offline
Send a message via AIM to 4everlearning
If you have to talk to a lawyer.
Old 02-08-2008, 11:14 AM
Free Faller
yeah you paid for a warranty, they should honor what ever is in the contract.
Old 02-08-2008, 12:37 PM
I don't believe they have even tried approaching Ford about doing the work under warranty. Can someone tell me if poor fuel filter mtnce can lead to the EGR cooler problem?
Thanks to all who have taken the time.
Jr
Old 02-08-2008, 12:40 PM
anniejrt anniejrt is offline
in the owner's manual for my excursion, it states several times/places that failure to do the routine/preventative maintenace(like 7,500/15,000, etc) stuff 'could' cause the warrenty to be null/voided.
Old 02-11-2008, 02:13 PM
motorace motorace is offline
call your local ford rep, the dealer is screwing you. i have never had to show any records.
i just had my engine replaced with 98 miles left int he warranty.
Old 02-21-2008, 10:01 AM
Update to close thread for those in my situation.....you are correct, after a close examination of my warranty it does state in several places that failure to perform required Mtnce that causes part failure will void warranty. The key word however is "Caused". After the repairs were completed on my truck ($3,100 bill) I had several long meetings with the service manager and shop foreman. They were unable to provide ANY evidence that my failure to change the fuel filter in accordance with the mtnce schedule CAUSED the EGR Cooler & Sensor failure. In fact I learned that the decision that it would not be covered under warranty was made "in-house" without presenting the situation to Ford at all, even though previous statements by my service advisor clearly indicated that it was Ford who would not warranty the repair. I learned of this by requesting the written response from Ford stating that they would not warranty the repairs. To make a long story short, I convinced the service manager to request Ford warranty coverage for the repairs. I also stated that I wanted Ford's response in writing....to include the causal relationship between lack of fuel filter mtnce and the failure of the EGR sensor and cooler. Within hours, I received a call from the service manager stating that Ford would in fact pay for the repairs under warranty.
The fiasco was unbelievable. My truck was in the shop for a month, and it took two, one hour long meetings with the shop foreman and the service manager to even get them to approach Ford for the warranty coverage.
Unfortunately, my town has only one Ford dealer.
Thanks to all who replied.
Old 02-21-2008, 10:28 AM
lifewitlooie lifewitlooie is offline
COLLEGE KID
Send a message via AIM to lifewitlooie
Stick it to the Man.
