Truck nightmare or am i just to being dumb? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 04-11-2013, 03:06 PM Thread Starter
JustinOOO9's Avatar
Quoted: 503 Post(s)
Garage
so usual ran ect 187 and eot 194. while driving down freeway then one day starting puking coolant. took it to a guy Sinister said installs all their parts. and had 21.5 psi in coolant system.... so he said $3110.00 for studs, egr delete, oil cooler, and blank plugs, up pipes and leaking glow pug harness. and thermostat (I did flush and supplied cat elc-1 by zerex and distilled water)
I drained all ford gold coolant and put 2 qrts of vc-9 and filled with garden water. let it run for around 45minutes up and down freeway pushing really hard (ecot and eot both went above 200 multiple times) . let it sit for little bit and opened drain valve on bottom drivers side and heater core line on pass side. and stuck a garden hose in degas fill opening and let it overflow while i did a couple of WOT and let the water pump push stuff out. then ran 2 flushes with flat out distilled water before I drove it up to him.
on the drive back my ect was 192 and eot 201-202 65mph at 90degree F outside called him and he said that's fine you dont need to worry til oil is like 250 something and stuff. I was just upset because now temps are worse and backwards.... went from a 7 degree split to a 10-12 split with EOT higher then ect. I want to trust the guy because sinister flatout said call this guy we dont install our stuff this guy does etc.. he sent me pics of the truck with the cab off and really knew his stuff.
Is this a possible clogged oil cooler, or bad sensor? I just drained my saving account for this truck and honestly Im feeling like burning it to the ground. or is it because of egr delete and different coolant?
sorry just confused and everyone here has been very helpful.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #2 of 27 Old 04-11-2013, 03:18 PM
06Lariat_'s Avatar
Sounds like oil cooler did they use a stock or the original?
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #3 of 27 Old 04-11-2013, 03:22 PM Thread Starter
JustinOOO9's Avatar
Quoted: 503 Post(s)
Garage
on the reciept new oil cooler. Im just so ticked becuase when I drained the ford gold crap it was super clean and the first coolant filter change before heads blew was super clean too. and when the vc-9 water came out clean as a whistle and now this crap!!!!! should I just call the guy and ask about it again? i already asked yesterday and i feel bad for bugging him but im furious too how an oil cooler could clog again in less then 90 miles!!!
ugh sorry
Justin,
post #4 of 27 Old 04-11-2013, 03:23 PM
PHYRMN's Avatar
21 psi coolant pressure is either a bad EGR Cooler or Headgaskets, coolant pressure on a healthy system should only be around 8 to 10 psi. Flushing the coolant system is well known for clogging oil coolers. EOT will always be higher than ECT, but should not be more than 15 degrees higher. More than 15 degrees has the tell tale signs of a clogged/clogging oil cooler. Your looking a almost 1400.00 just in parts you listed. I added in the cost of the OEM head gaskets. So he's only charging around 1700 in labor, thats not too bad in my book.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #5 of 27 Old 04-11-2013, 03:25 PM Thread Starter
JustinOOO9's Avatar
Quoted: 503 Post(s)
Garage
I had a bulletproof egr cooler installed like 6 months ago and she just randomly started puking coolant. but i only had 7ish degree split before the flush with vc-9 and distilled water. and then he installed brandnew oil cooler and egr delete and now my temps are crazy!! 11 difference with EOT being higher then ECT?
im not a ford tech so I wanna learn as much as possible before I call him im super ticked right now....
Justin,
post #6 of 27 Old 04-11-2013, 03:28 PM Thread Starter
JustinOOO9's Avatar
Quoted: 503 Post(s)
Garage
Sinister and the guy gave me a deal being Military and I just happened to have barely enough cash so I didn't have to use credit card and I drove my 84 4runner crawler project while waiting for truck. so should i
1. call and ask for more info? politely...
2. call and ask if he can do the oil cooler again or
3. burn the truck to the ground and claim insurance I really like the truck but im 24 and have sunk a ton of money because of my ignorance lol...
Justin,
post #7 of 27 Old 04-11-2013, 03:33 PM
PHYRMN's Avatar
If you BP'd the EGR Cooler, the failure rate on those is extremely small. I would have to lean towards headgaskets. 11 Degrees higher EOT isn't crazy high, but it should be watched frequently. With leaking headgaskets you now how combustion gasses in the coolant system, which can cause things to start failing sooner, the domino effect. With stock head bolts and original gaskets, I'm afraid it was just a matter of time.
PHYRMN is offline
post #8 of 27 Old 04-11-2013, 03:37 PM Thread Starter
JustinOOO9's Avatar
Quoted: 503 Post(s)
Garage
ahh crappolaa im sorry he even installed OEM headgaskets i forgot.... so even though my EOT is 10-11 higher then my ECT you think im good im just so confused but im still ignarant to the 6.0 working...
1. ect are supposed to be higher...
2. my split was smaller and ect was higher...
3. yes i got a good deal and It was a Blessing (dont believe in luck)
im stumped thx for reading everyone I just dontt wanna bother the mechanic becuase sinister likes him and he helped but why is the oil temp higher then ect now?
Justin,
post #9 of 27 Old 04-11-2013, 03:40 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
This sounds like what happened with my truck. I was having oil cooler problems after a flush, so I ended up having an BPD egr cooler installed along with a factory oil cooler. I was still seeing oil temps in the 230 range. Turns out my brand new oil cooler from ford was blocked! BPD got ford to warranty it, since I bought it from them. Even after having the second new oil cooler put in, my temps weren't quite where they should have been. I ended up replacing the radiator, it was pretty well plugged up from the flush. You may want to look there first. Get yourself a non-contact thermometer, after the truck is up to temp, check the temperature at the top of the radiator and then at the bottom, there should be a 20-30 degree difference. Mine was only about 5 degrees apart when it was clogged.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #10 of 27 Old 04-11-2013, 03:43 PM
PHYRMN's Avatar
1. Incorrect, Oil Temps will be higher when truck is up to normal operating temps, mine EOT's will be below Coolant temps until she's fully warmed up, then the Oil Temps will climb past the Coolant temps by 8 to 10 degrees on mine.
2. It's very possible that the flush caused loose particles in the coolant system to collect in the cooler. It happens all the time when flushing the coolant systems on 6.0L's.
3. My 6.0l guy gave me a good deal because of being in the military too.
OEM headgaskets and ARP Studs are the best combo for our trucks, history has dictated this many times.
PHYRMN is offline
