I'm stumped.. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-11-2013, 02:04 PM Thread Starter
I'm stumped..
Ever since I got my ScanGauge, I've had issues with high eot's. I did a coolant flush to get the ford gold out but then I realized that everytime I go to start my truck in the morning, The eot is around 110*, which makes no sense since the outside temp is around 70*. All my other temps (ect, tft) are around outside temp.
Now the real problem is it's like the eot is always reading 40-50* higher than it should. The main issue with all this being everytime I go down the interstate for more than ten miles, the truck goes into limp mode because the eot's will hit 260*. I replaced the probe for the eot's right beside the oil filter and that didn't do a thing, but I don't know what else to do. Could the ecm be screwed up or what?
2006 F250 ECSB 4x4 Lariat
168k Miles|FICM by Ed w/ Atlas 40|SCT X4 with Tunes by Vivian|MBRP 4" TBE|Zerex ELC|EGR Delete and Coolant Filter by Custom Diesel|ARP Studs|OEM Gaskets
2008 F450 CCLB 4x4 XLT
141K Miles|Bone Stock for Now...
jtheado is offline
post #2 of 13 Old 04-11-2013, 03:32 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Replace the sender unit or you can swap the ect with the eot sender, they are the same part #. You will need to replace it for the long term.
Look at it this way: better than a bad oil cooler
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 13 Old 04-11-2013, 03:46 PM Thread Starter
I did replace the eot sender with a new one and it didn't make a difference...
Sent from AutoGuide.com App
jtheado is offline
post #4 of 13 Old 04-11-2013, 04:03 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Try pulling the battery cables to both batteries and turn on headlights and hold down brake to discharge system all the way and then power back up. Maybe the computer is in a funk ??
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #5 of 13 Old 04-11-2013, 04:20 PM Thread Starter
I unhooked both batteries for 45 minutes and that didn't help a thing. I'm not sure what the deal is?
jtheado is offline
post #6 of 13 Old 04-11-2013, 04:24 PM Thread Starter
I left the new sensor in the motor and unplugged the connector and plugged the old one in and set it onto of the motor (which hasn't been running) and it reads 125* while the air temp is 64*. Idk if the computer is having issues or what?
jtheado is offline
post #7 of 13 Old 04-11-2013, 04:51 PM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Check over the harness for chafing. The sender works off of resistance and if there is some grounding along the line it will cause it to do that. Also look at the pigtail for grease in it, must be clean clean.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #8 of 13 Old 04-11-2013, 05:05 PM Thread Starter
I'll try that tomorrow since it's dark out. It's a huge pain because I can't even drive the thing without it going into limp mode because it says it's getting so hot.
jtheado is offline
post #9 of 13 Old 04-11-2013, 05:06 PM
PHYRMN's Avatar
Please don't be offended, but are you sure you pulled the oil temp sensor?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #10 of 13 Old 04-11-2013, 05:17 PM Thread Starter
Lol no offense taken i know how some stupid people are. Yes it's the correct one. I check my unplugged the connector while leaving the sender in place, and connecting the old sender to the connecter and laying it ontop of the motor and the reading went way down.
I went out and looked at the pigtail and everything looks good. No rubbing or chaffing. Idk if the ECM is having issues or what? I don't have a tuner to try and new tune other than stock to see if that helps and the only thing I can think of is a reflash from the stealer.
jtheado is offline
