Cold Start - Ford Powerstroke Diesel Forum
Old 02-06-2008, 07:17 PM
Cold Start
When it cold and i start my truck it idles really rough almost like a car with a huge cam is that normal? but it only for like 15 seconds?
Old 02-06-2008, 07:22 PM
how cold is it? and also it a 7.3 or a 6.0
Old 02-06-2008, 07:24 PM
Plug It in....its a big displacement non spark ignition engine..if that doesnt solve the problem. i was told by a PSD mech. that he has tried many things to stop that even when plugged in..he changed the clutch on a truck and the shake stopped...so i dont know what to tell you if the plug in doesnt help..my truck does it when not plugged in for like 5 sec. in cold weather.
Old 02-06-2008, 07:28 PM
about like 28 and its a 6.0
Old 02-06-2008, 09:32 PM
im do not know much bout the 6.0 but i could tell you bout the 7.3. but i think it just might be that international is a little rough in the cold cause every international i have does that when its cold out side. try plugging it in
Old 02-07-2008, 02:20 PM
i plugged it in last night and it didnt do it guess it just when i dont plug it in... but now the check engine light keeps going on and off ah haha
Old 02-07-2008, 02:44 PM
Ford issues a TSB on this issue a while back, here is their offical statement from Dieselmann's website.
"94-03 7.3 Idle Lope on Cold Start:
Ford has determined that the engine loping on a cold start is a characteristic of the engine. They are recommending to use a lower viscosity oil--10W-30 meeting API service CH-4 or CI4--to reduce the condition. They also suggest plugging in the block heater when outside temperatures are below 30 degrees and/or waiting up to two minutes with the key on before starting the engine to allow the glow plugs to fully heat the cylinders. Broadcast Message 1050."
Old 02-07-2008, 02:51 PM
My 03 6.0 sounds like I got the nastiest cam in my truck. Thats normal especially if you have a chip. But mine doesn't do it if its plugged in. I kinda like it though!
Old 02-07-2008, 03:15 PM
You wouldn't like that sound if you knew what it was doing to your injectors! You guys need a lighter weight oil for cold temps. My truck doesn't do that anymore with 5W40.
Old 02-07-2008, 08:05 PM
is there any way to tell if u have a chip? cause i just bought it
