i need an expert to set me straight... - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-09-2013, 04:46 PM Thread Starter
ok i have replaced my oil cooler and installed an egr delete from synister diesel. ive installed a coolant filter, im running zerex extreme heavy duty coolant, have an edge cts to keep an eye on things.
now for where im probably wrong, i know i did a coolant flush before i had my cooler changed, (this was at the end of last summer) ive put maybe 3000 on the clock since then. before i had all this work done my temps were way out of wack, then i had the work done and everything was looking good, truck runs great, temps look good all the time (ofcoarse its winter) now the weather is starting to warm up and my temp look all screwy again. eot is about 200-205 and ect is usually about 179-182. now obviously thats a big spread for just having all this work done. or so i think... heres where im confused..i thought that if your coolant temp was higher than you oil temp by 15 or more deg that you were up the creek and needed a new cooler. is this right or does it not matter which temp is higher? obviously everyones truck is gonna be a little different but what is the norm? i somehow think my coolant is running too cool but since when is that ever a problem? hope this helps more than just me
terry6.0 is offline
post #2 of 14 Old 04-09-2013, 05:04 PM
PHYRMN's Avatar
Oil Temp shouldn't exceed Coolant Temp by more than 15 degrees. EOT will almost always be higher than ECT. Your coolant reading is a little low, I dont know what your ambient temps are where you live right now, but I would suspect that your thermostat is starting to show some issues. Thermostats are supposedly set to start to open at 192. As they start to fail you will notice the coolant temp start to fall under normal operating conditions. The delta cant be read accurately unless the coolant temp is above 185 degrees.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 14 Old 04-09-2013, 05:14 PM
taskforcefreddy's Avatar
^^ what he said. Need to replace your t-stat and then get some readings. Looks like its stuck wide open.
Sent from AutoGuide.com App
taskforcefreddy is offline
post #4 of 14 Old 04-09-2013, 05:39 PM Thread Starter
ok, ill start there... so what is the down side to your coolant being too cool?
terry6.0 is offline
post #5 of 14 Old 04-09-2013, 05:46 PM
twoicebergs's Avatar
Quoted: 42 Post(s)
In any case, if that is steady-state, your oil cooler is almost clogged again. The good news is you may be able to back-flush the coolant side without removing it. It might be worth a try.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 14 Old 04-09-2013, 06:05 PM Thread Starter
what do you mean "steady state"? what symptoms differenciate a stopped up cooler vs a open t-stat? and why the hell would it be stopped up again? if it is it will be for sale.
terry6.0 is offline
post #7 of 14 Old 04-09-2013, 06:31 PM
Quoted: 42 Post(s)
Up to near normal temps on a flat surface, empty at 60-65mph for 5-10 minutes. The differential for the oil temperature will be fairly similar from about 175-200 ECT. I knew my T-stat was opening and running low. My delta was 8* whether the ECT was 175 or what ever. When I replaced my T-stat, ECT 190, the EOT was still 8* warmer.
The second clogging is somewhat normal. Do a search and see how many others have had this happen. The coolant system has to be really clean or disturbing the system will put new (no longer stuck to the sides) debris into the coolant.
Frank
Working for Toys
post #8 of 14 Old 04-10-2013, 06:11 AM Thread Starter
ok, just as a liitle background info, when i did my coolant flush i ran 45 gallons of distilled water through it. the first id say 20 gallons were just horrible looking then each jug got progressivly lighter, by the time i got to #45 the water coming out was as clear as what was going in... with no change in temps i had my cooler replaced. i just cut open my coolant filter this morning and there is hardly anything in it. this is the second filter iv had on the truck since work was done. first filter was gross, this one (#2) is fairly clean, little dark brown gritty substance it in but no brown slime like the old cooler had. i think im gionna shoot for a new t-stat first and see what happens. start at the cheapest point they say...then ill get some more numbers. i shall return.... thankyou
terry6.0 is offline
post #9 of 14 Old 04-10-2013, 10:23 AM
southend's Avatar
Inefficient combustion process, possibly lack of mpg, increased soot, and possibly dirtier oil.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #10 of 14 Old 04-11-2013, 03:38 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 442 Post(s)
Garage
Yea change that thermostat and see how it does. Make SURE you put a OEM one in there ONLY.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
