Black and white smoke. Pls help! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-08-2013, 07:21 PM Thread Starter
I just recently changed out my number 5 injector. Drive good for a few weeks. This past weekend I hooked up to a small cargo trailer and went on a 5 hour drive. About 2 and 1/2 hours in I pulled up to a red light and I had a ton of white smoke like before when my EGR cooler went out. As soon as I hit on the gas it turned black. I pulled over took some codes and had 2,4,5,8 contribution codes and EGR code. My EGR is deleted so I didn't understand that. Well I let it clear up and try to drive a little bit further. Well about 3 miles down the road I lost all throttle response and as I pulled off the road it died and locked up my wheel. After letting it sit for a little bit I tried to crank it but my starter wouldn't in gauge. So I towed it the rest of the way. Started tearing down to see what the #5 looked like. I got it out and the copper o-ring was gone. Wasnt even in the valve. The tip had so much black residue. I assume that's where my white and black smoke came from. Could the starter be a freak accident? All opinions well greatly help
Roughneck88 is offline
post #2 of 5 Old 04-08-2013, 07:24 PM Thread Starter
Right before I went on the trip I changed oil to rotella t6 with rev x. Before I just used rotella 15-40. Could that have affected the injectors when I've been running the 15-40 for 2years know.
post #3 of 5 Old 04-08-2013, 09:50 PM
May be hydrolocked. Pull that glowplug and see what comes out.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #4 of 5 Old 04-09-2013, 12:44 PM Thread Starter
What will the glowplug look like if it is hydro locked?
post #5 of 5 Old 04-09-2013, 04:13 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Your not looking at the glow-plug, fluid would come out with a slow cranking. However, you already pulled the injector. Use a vacuum extraction tool with a small tip to suck out the cylinder. Clean the injector cup with a tube brush and again suck out any debris. The cooper washer is probably still in the cup, unless it was MIA from the previous install. Make sure you have a clean injector cup with no washer in the bottom! If it was MIA, it lasted a long time before blowing the fuel o-ring. You might want to have the injector checked. If you are really concerned about #5, replace the nozzle, however, a new set of o-rings and a new copper washer for #5 should work in this case.
Your contribution codes were probably due to exhaust gas getting into the fuel rail.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
