2003 6.0 running hotter then normal - Ford Powerstroke Diesel Forum
post #1 of 36 Old 04-08-2013, 04:06 PM Thread Starter
mxrider777's Avatar
My truck normally doesn't get to over a 200 degree oil temp,when driving slow this weekend through some trails my oil temp got up to 210 unloaded ect also reached 210 at the same time then cooled back down, now after driving today normally my oil temp got up to 201 within 20 minutes of driving from 0-50mph through the city and once on the highway went up to 205, my deltas are within 10* It Has only been doing this for the a couple weeks and this is all unloaded but I am on 43 inch tires, IS this normal? I live in florida too no puking,zerex coolant,coolant fiter
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
sinister coolant filter
zerex elc coolant
edge insight
Egr Delete w/ coolant reroute
mxrider777 is offline
post #2 of 36 Old 04-08-2013, 04:42 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Change your thermostat and use only a OEM. The oem will fail in the open position unlike aftermarket thermostats.
Kinda sounds like you may have a aftermarket one in the truck to me. I would go to dealer and pick one up. Also look at the radiator for being plugged up with debris.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 36 Old 04-09-2013, 04:30 AM Thread Starter
mxrider777's Avatar
Thanks alot, would you recommend putting the old coolant back in once drained to put the thermostat in? cause i just did a coolant flush 4,000 miles ago
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #4 of 36 Old 04-09-2013, 05:42 AM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Sure as long as you drain it in a clean container.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #5 of 36 Old 04-09-2013, 10:30 AM
Rick C's Avatar
IMHO...anything you drain out...stays out. These things contaminate fluids so easily that to me...it just isn't worth it. I would be doing a flush too. Even if it's off schedule. But...just my 0.02.
2005 F-450 CC Fontaine Conversion
(It's the heavy GVW one with the Dana 135, 4:88's and bigger brakes)
Link Air Ride Suspension
Banks Stuff (CAC, Exhaust)
EDGE CTS
SCT x3 with Eric's tunes
Bullitt Proofed (EGR mod, Remote oil cooler/filter, Water Pump, 7.3 fan clutch conversion)
ScanGaugeII
Odyssey AGM's
High Idle Mod, CCV Mod
ARP studs...Finally
More $$$ to be spent i'm sure!
Rick C is offline
post #6 of 36 Old 04-09-2013, 12:00 PM Thread Starter
mxrider777's Avatar
Even if you just did a flush?
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #7 of 36 Old 04-24-2013, 06:29 PM Thread Starter
mxrider777's Avatar
Finally had time to install a new ford thermostat temperatures are better and deltas are still good but my oil temp is still getting up to 201 any suggestions? ect is at 194 when eot is at 201
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #8 of 36 Old 04-24-2013, 06:33 PM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 488 Post(s)
Your EGR may have failed.
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #9 of 36 Old 04-24-2013, 06:37 PM
Anti-Hashtag Member
Quoted: 488 Post(s)
If your EGR failed it failed awhile ago and your oil cooler is now failing. If do you caught it early.
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #10 of 36 Old 04-24-2013, 06:40 PM Thread Starter
mxrider777's Avatar
So i need an egr delete before my oil cooler fails?
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
