Coolant level Question/ ECT & EOT - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-08-2013, 12:15 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
First question: coolant level was low while running hot- i could shake it and see a little bit of coolant in degas, when I shut it down i quickly walked over to the engine and saw it had immediately rose to the minimum line- is this good/bad that it rose so quickly after shutting down?
Second: my IAT is at 160* +/- when i pulled off the highway and idleing. While driving it was 110* +/- are these temps too high?
Its 80* outside: My ECT and EOT are at 215* with a 6* maximum delta. and EGT are at 1200* while driving around 50mph, i did not let them get any higher... Heres the thing, the ect and eot do not go down below 200* when i let it sit with the hood open and an electric fan on the engine for ten minutes. Alsooo, when it was 30* outside last month, my ect and eot never went above 180 and it usually was around 175... Is this bad coolant or bad thermostat?
Also, there is a coolant temp sensor on the oil cooler housing and i guess another one on the thermostat?
I gotta hual 10 cubic yards everyday this week and wanna make sure its not heads going or gonna break down on me. Thanks guys
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #2 of 18 Old 04-08-2013, 12:19 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Also, i get a studder when i am idling at these temps- similar to a bad ipr or icp- the engine will jump and idle rough. Icp readings are exactly where they should be though.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #3 of 18 Old 04-11-2013, 10:18 AM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Anyone!? Not sure if this is related but my a/c only works while idling... at speed it blows outside temps.
Any help would be appreciated
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #4 of 18 Old 04-11-2013, 11:32 AM
PHYRMN's Avatar
Your thermostat needs replacing, get a Ford one, they have better longevity than the store bought ones. The zoodad mod will help bring the IAT's down considerably. My IAT1 is always at ambient temperature and my IAT2 is usually just 30 degrees above that. Not sure about the a/c issue, check a/c coolant and compressor clutch. Coolant level in the Degas bottle should normally be around an inch up from the bottom of the front of the degas bottle.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #5 of 18 Old 04-12-2013, 07:01 AM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Hey thanks for your help. I will look up the zoodad mod. Which sensor is the IAT1 and 2 i know there is a IAT sensor on the drivers side manifold but where is the other one?
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #6 of 18 Old 04-12-2013, 07:55 AM
PHYRMN's Avatar
IAT1 is at the MAF sensor on the plastic tube near the air filter, IAT2 is the sensor inside the Intake Manifold/Plenum.
PHYRMN is offline
post #7 of 18 Old 04-14-2013, 03:37 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Thanks. I replaced thermostat and coolant and now the temps are around 200* consistently... Guess it is the 203* thermostat... now its on to figure out why my truck idles like crap when it warms up and run it hard. Most likely have some injectors crabbin out.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #8 of 18 Old 04-15-2013, 08:10 AM
Whats your FICM voltage? I had a rough idle until I got my rebuilt FICM
bfordu is offline
post #9 of 18 Old 04-15-2013, 07:26 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Never went below 47.5 while cranking. Its possible ficm is going bad.. Two injectors were deemed "failed" revx cleared them up but i think rev x only delays the problem at hand
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #10 of 18 Old 04-16-2013, 04:52 AM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Update: I replaced thermostat and coolant with motorcraft gold and my truck warms up faster and my deltas and temps are alot better.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
