Low on power - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-08-2013, 11:31 AM Thread Starter
Low on power
I have a 2004 6.0 and recently it started acting up on long trips. After you run it for a while it will start to run rough and lack power. I'll have to floor at a stop light and it will barley get enough power to get going then the turbo kicks in and it takes off. It doesnt seem to smoke at all when this happens. I thought it might be the fuel filters so I replaced those but that didnt solve the problem. my next guess is that I'm gonna have to install an EGR delete but I'm not sure if that is the solution to my problem or if that might only be one part to my solution. Wondering if anyone had any input.
Thanks in advance,
JT
___________________________________________
2004 F250 CCSB SRW Lariat
K&N Intake
MBRP 4" Straight Pipe Turbo Back
EGR Delete
ARP Studs
JL Audio C2-570x
Black Harley lights
DDM tuning 55w 6000k headlights and fog lights
Recon Lighting third brake light (smoked)
jtpowerstroke is offline
post #2 of 3 Old 04-18-2013, 05:56 PM
Ever figure it out? My '04 acts similarly, low power then all of a sudden the turbo kicks in. I've been thinking it's sticky vanes in the turbo but they were allegedly cleaned last year.
tomshane is offline
post #3 of 3 Old 04-18-2013, 08:40 PM
pull ebps tube (driver side exh. manifold )and sensor, looks almost like a coolant temps sensor with a brake line from the exh. manifold to sensor base. Mine was almost entirely plugged with soot (at 60k ish i dont remember exactly) and acted similarly to what you are describing.
Mark
04 -rclb
RCD EGR Delete
Sctx3 with tunes from Vivian
Xdp coolant Filter
Global charge coolant
5" MBRP
MarkBart is offline
Tags
egr delete , no power
