Low Fuel Pressure Issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-06-2013, 06:44 PM Thread Starter
6.0DSLPWR's Avatar
My truck developed a leak from the fuel pressure regulator so I figured what better time to install the blue spring and a fuel pressure gauge so today I did just that. I cycled the key three times then fired the truck up and my isspro gauge is reading about 18 PSI at idle. I drove the truck and at WOT the needles drops slightly to about 16 PSI. I quickly checked for leaks and I do not notice any. I am wondering if something could have gone wrong with the blue spring install that is causing this or would a little bit of air cause this? I think tomorrow I am going to remove the isspro sending unit and install a mechanical gauge to verify the pressure before I go any further.
Has anybody else seen this low of pressure from a 6.0 before?
-Aaron
2005 Ford F350
SCT X3
Isspro Performax Gauges
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
MBRP Dual 4" Straight Pipe
Harley Headlights
Pioneer In Dash GPS
6000K HID Headlight and Foglights
Smoked Lights
6.0DSLPWR is offline
post #2 of 6 Old 04-07-2013, 04:03 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 276 Post(s)
If that pressure is actual it will quickley ruin injectors. You never want to see anything below 45 PSI, but with the blue spring you should never see near that, unless you've gone large on your injectors, and then you will have to upgrade more than just the regulator
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #3 of 6 Old 04-07-2013, 06:29 PM Thread Starter
6.0DSLPWR's Avatar
Well I put in a mechanical gauge today and I have 70 PSI at idle so something is up with my new isspro gauge. I have a part number from the sending unit and am going to verify I have the correct one. If it is the correct one then I probably have a faulty sending unit. I know either way isspro will take care of me.
-Aaron
2005 Ford F350
SCT X3
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
Harley Headlights
Pioneer In Dash GPS
Smoked Lights
post #4 of 6 Old 04-08-2013, 04:43 AM
Quoted: 276 Post(s)
Yes ISSPRO will take care of you. I started to have a problem with my HPOP gauge, to where it would make the truck act like a bad ICP sensor. I was in communication with a guy named Mike Pliska. They determined it was a bad harness and sent one out to me free of charge. I love their product, and I love their support
post #5 of 6 Old 04-08-2013, 10:53 AM
04fivefour's Avatar
If you used teflon tape make sure none covered the sensor hole. Had that happen on mine and it would hope from 10 to 100.
2004 Excursion 6.0
Originally Posted by Snake View Post
Some feminazi would claim that the part name and location indicates that a woman's place is in the passenger seat. Which is just wrong. We all know its in the kitchen.
04fivefour is offline
post #6 of 6 Old 04-12-2013, 02:29 PM
MichaelP's Avatar
Sorry, missed this thread until now. Has it done it since the beginning? If so I suspect we sent you the wrong sensor. What is the part number on the sensor?
Thanks,
Michael Pliska
Engineering Manager
1995 F350 PSD CC DRW, 271k miles
10 ISSPRO Performax™ gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" DP, Tymar 5" exhaust, Cat's lost, Baby Swamps, Swamps tuning, Tricumulator springs and Accumulator Valve, Tru-Cool 4590
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET)
92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 T/A 455
GOA, IDPA & NRA member and certified firearms instructor
MichaelP is offline
