Standpipes/Dummy plugs installed incorrectly!?!? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-06-2013, 01:21 PM Thread Starter
chozenfew805's Avatar
I've been having some hard starts, no starts when cold, and intermittent no starts when hot on my 05 6.0PSD CC. It went to the dealership for the STC fitting upgrade in 08 but haven't completely ruled that out. I did some research and talked to a mechanic at the local dealership. He recommended I replace the dummy plugs and standpipes. So I bought the parts and and installed them the other day.
Now when I was installing the passenger side standpipe, the lower half slipped into the blockand I looked at the upper half and thought it'll mate up once I torque it down. Well long story short, I've tried to start my truck about 8-12 times about 15second intervals and no luck.
I did not add any oil to the oil rail when I replaced the dummy plugs and standpipes but pretty much don't know what else to do. I've checked the all the wire connections and anything else I needed to remove when I performed the job but I'm pretty much dead in the water.
Any help or advice to get me back in the right direction would be awesome?
chozenfew805 is offline
post #2 of 3 Old 04-06-2013, 03:32 PM
hmm.. The standpipes will mate- it doesnt take any special strategy to mate them. just insert the upper part of standpipe and torque to 60 ft.lbs... You might have another issue- what is your icp reading showing? It could be the stc fitting, hpop, or injector o-rings, icp sensor, or ipr sensor
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 3 Old 04-06-2013, 05:36 PM
my0460's Avatar
I did mine and it took a few 30sec. cranks to get it fire up. Just give it some cool down between cranks.
04,cc,sb,4x4.
egr. delete
sctx3
over mirror gauges.
mbrp 4" no cat,no muffler.
my0460 is offline
