A good brain teaser - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-05-2013, 08:19 PM Thread Starter
A good brain teaser
07 f350
-truck smokes like it's over fueling, really high egts when towing, i cannot run any tuning when towing or my egts are uncontrollable. in stock form I'm seeing an easy 1200F with aprox 7000lbs behind me, at half throttle pulling up a hill.
-new injectors, new turbo, both stock (tried two sets of injectors)
-head studs and gaskets
-new oil cooler, egr delete, all updates done
-4" exhaust straight to the tip dp is wrapped
-custom y-pipes also wrapped (keep heat out of the engine bay)
-swapped every sensor on the engine over time with either new/or known good sensors, never any change.
-fuel pressure is good
-oil pressure is good
-coolent and oil temps have always run hot ever since i've owned it. Running empty i normally see 200-205F coolant, oil temps stays within 5degrees empty, running loaded it never passes the magic 15....(might just have a cold weather thermostat in it, it did come from the north)
-transmission temps are good, shifts are strong, nothing slipping.
-smoking has gotten worse now that the weather is warming up
-smokes a little even at idle.
I did run into a guy that figured he had similar issues, and an aftermarket turbo fixed it for him.....thats not really an option for me right now.
Thoughts, comments, suggestions?
JefftheCanuck is offline
post #2 of 14 Old 04-06-2013, 06:45 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
It sounds like your turbo or charge air system is not operator correctly. However, other issues could be the EGR staying open or even an up-pipe exhaust leak. Of course, your EGT gauge could be misreading, but that wouldn't explain the smoke. Have you checked your FICM voltage? If the firing is off, that would cause smoke. There is no reason for you to have high EGTs or high ECT/EOT.
Running a hot T-stat is highly unlikely for it to be that high - a few degrees at most. I live where it is real cold, and a normal T-stat works just fine. Water pump issue as well or a blockage?
Did anyone stuff a tennis ball up your exhaust? How's that for a brain teaser? Butt teaser?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 14 Old 04-06-2013, 07:47 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
butt teaser >.> thats a bit kinky for my taste but then he wouldn't be smoking it would just be EGTs.. which at that level of heat and pressure i would hope it would melt the tennis ball
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #4 of 14 Old 04-06-2013, 05:53 PM Thread Starter
I never remember to write everything down when I'm filling people in on this problem.
-FICM has been replaced with a Swamps 58V (stock tuning), also tried a test FICM just in case.
-tried a different EGT probe, but thats not to say my Insight isint out of wack, might try a standalone egt gauge and see what it says.
-EGR system has been deleted and i'm running new custom built y-pipes
-as far as the tennis ball goes, I've actually replaced the entire exhaust system since this problem developed
I'm not sure on the H2O pump, everything seems fine there, in my experience my temps aren't too far out too lunch, it's mostly the EGTs that I'm worried about
I agree with you on the charge air system not functioning properly, I am trying to get somebody to write me a tune that will pull back the fuel and get the turbo spoolin up a bit more. It really just seems like it's not getting enough air. Stock injectors shouldn't smoke like this.
I'm a diesel mechanic, I really wish these things had wastegated turbos, would make life a heck of a lot easier.
post #5 of 14 Old 04-06-2013, 05:59 PM
Powerstroke Techie
How much boost is it making, and what air filter is in your truck?
is it pulling the minder in at all?
Over fueling/not enough air, one or the other.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #6 of 14 Old 04-06-2013, 06:27 PM
MoserJR82's Avatar
[QUOTE=twoicebergs;4839786]It sounds like your turbo or charge air system is not operator correctly. However, other issues could be the EGR staying open or even an up-pipe exhaust leak. Of course, your EGT gauge could be misreading, but that wouldn't explain the smoke. Have you checked your FICM voltage? If the firing is off, that would cause smoke. There is no reason for you to have high EGTs or high ECT/EOT.
I would have to agree, especially without knowing how much boost you're making. Sounds like you're getting too much fuel or not enough air or both..
2005 F-350 KR, CC, SB 6.0L
Sinister EGR Delete
Final Charge Coolant
Rotella T6 5w40
MBRP 4" turbo back straight pipe
Blue Spring Upgrade
Droid Torque App
SCT X3 Spartan Hyrbid Race Tune
ARP Head Studs
Aftermarket degass cap
Cowl hood (not functional)
Atlas 80 PHP FICM tune
Rebuilt FICM thanks to FICMRepair.com!
Rancho RS9000X front shocks
MoserJR82 is offline
post #7 of 14 Old 04-06-2013, 08:52 PM Thread Starter
fully loaded or at WOT i'm reading 25-27psi on the Insight. That said before I did my EGR delete i was reading up to 30psi on the Insight. A couple psi could make the difference.
I'm still running the stock air filter, not pulling in the restrication indicator at all, I've tried running briefly withought the air filter, no difference. Gonna try this again, see what happens.
post #8 of 14 Old 04-07-2013, 05:20 AM
southend's Avatar
Clogged cat?
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #9 of 14 Old 04-07-2013, 07:09 AM
Quoted: 46 Post(s)
Unless you are running a hot tune with wide PW at lower RPM and boost, stock will not smoke. Your boost seems fine. Anything over 20psi should not smoke at all. However, if your vanes are stuck more open, it could smoke at lower boost and rpm. With what you have added, I would look more at inspecting/cleaning the turbo. The other area to check is your new up-pipes for leaks, but the ability to generate boost don't really support a big problem here.
If you had very late injection (something would have to be wrong with the PCM/FICM or a bad tune), that could cause this problem.
Going deeper, you might want to check your cylinder compression.
Frank
Working for Toys
post #10 of 14 Old 04-07-2013, 08:58 AM Thread Starter
-I've got smoke from light throttle (not as bad) to WOT(this is the worst point), there's even a bit of haze at idle (engine dosen't burn a drop of oil)
-I had the same problems before I replaced my y-pipes, old ones had no signs of leakage, new ones don't either.
-I honestly don't remember if I had these problems before I repalced the turbo, I was 100% stock at that point, there has always been a light haze at idle, which leads me to believe the problem was always there, but any form of tuning seems to agrivate whatever my issue is. I'm going to try and get my hands on an aftermarket turbo and see what happens......too bad MTW is offline right now, I'm sure Adrian could build me something to sort this out
-FICM has been replaced (original was low voltage), tried a test FICM to verify the new one didn't have issues as well. Swapped the PCM with a known good test unit, no difference
-Did a compression test when i had the cab off for studs, all cylinders are good, ~400-420psi. Also had my heads machined and pressure tested while off, 100% good, the block deck was almost perfectly true, any warpage was within spec.
Oh and I got rid of the kitty a long time ago.
