04 hpop discharge tube - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-05-2013, 05:08 PM Thread Starter
Im new to the forum and the diesel world. Bought a 04 6.0 couple weeks back and i am learning alot! I have read through many posts on here about several issue. I have one question. How do you disconnect the hpop discharge tube from the branch tube on a 04 late build? Im sure im beating a dead horse but any info would be great!
04 F-250 LARIAT CREW CAB LONG BED 4X4
AD 1.5
EGR DELETE
jnp6.0 is offline
post #2 of 12 Old 04-05-2013, 05:16 PM
PHYRMN's Avatar
You'll need a tool like this:
http://repairguide.autozone.com/znet...3f802087e0.gif
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 12 Old 04-05-2013, 05:23 PM Thread Starter
Can i get this tool at autozone or do i have to go to ford? How much do they run?
AD 1.5
EGR DELETE
jnp6.0 is offline
post #4 of 12 Old 04-05-2013, 05:30 PM
PHYRMN's Avatar
I got an after market one on ebay for about 25.00. Ford will charge you an arm and a leg for it.
PHYRMN is offline
post #5 of 12 Old 04-05-2013, 05:34 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I use the tool that comes with the air die grinders. As long as it will go around the tube, it will work.
dhanna6powerstroke is offline
post #6 of 12 Old 04-05-2013, 05:35 PM
PHYRMN's Avatar
Oil Line Disconnect Tool Ford 6 0L 3478 | eBay
PHYRMN is offline
post #7 of 12 Old 04-05-2013, 05:43 PM Thread Starter
Thanks guys hopefully once i replace this it will be the end of my hot no start issue lol! I have already replaced eveything else in the hpos due to inexperience. Thanks again
AD 1.5
EGR DELETE
jnp6.0 is offline
post #8 of 12 Old 04-05-2013, 05:51 PM
PHYRMN's Avatar
Check your discharge tube, the 03's and 04's had some instances of the discharge tube rubbing the HPOP cover. Ford came out with an updated cover that has a recessed area to add space between the tube and the cover. I had to do this to mine;
https://www.dropbox.com/s/pqcvgsrsnvmy0zm/Tube_2.jpg
https://www.dropbox.com/s/emcnrfpwq9ae4fp/Tube_1.jpg
Here's a picture of the updated HPOP cover, notice the curved, raised area on the top of the cover.
https://www.dropbox.com/s/iyugdz8wgfggk89/SAM_0176.JPG
PHYRMN is offline
post #9 of 12 Old 04-05-2013, 05:58 PM Thread Starter
I just looked at it and doesnt have an wear marks on the tube or the cover. Is this something i should since in in there anyway?
AD 1.5
EGR DELETE
jnp6.0 is offline
post #10 of 12 Old 04-05-2013, 06:02 PM
PHYRMN's Avatar
If you don't see any wear marks on the tube, your most likely ok.
PHYRMN is offline
