Blown head gasket? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 04-05-2013, 11:20 AM Thread Starter
UKShooter's Avatar
Blown head gasket?
I went outside to install my DashBoss EGT and Fuel Pressure addons today and crawl under the truck to find this:
Coolant has started dripping down my passenger side frame rail so I traced it as high as I could see and it is coming from up above where the block heater cord attaches. I can't see any higher but I tried to put my phone up in there and film with the light on. I don't know exactly where it is leaking from. Could this be my headgaskets or EGR or what?
HG Leak2? - YouTube
HG Leak? - YouTube
Also, noticed that there was a mouse nest underneath my turbo... I bought this truck from my grandparents after my grandpa passed away about a year and a half ago and they weren't too concerned with maintenance. I'm just glad it was the fireproof insulation from my firewall and the inside of my hood.
Any insight about whether this is headgaskets or not would be appreciated. The first picture is of the mouse nest under the turbo.
ID:	92994   Click image for larger version
ID:	93010   Click image for larger version
2005 King Ranch CCSB 6.0L
  • SCT X3
  • DashBoss w/ Fuel Pressure Monitor
  • High Idle Mod
  • Fog Light Grounding Mod
  • Magnaflow 4" Turbo Back
  • IPR EGR Delete and Up Pipe
  • New Oil Cooler @100,000mi
  • Updated Turbo Oil Feed
  • STC Update
  • New Stock Injectors @130,000mi
  • Blue Spring
  • CAT ELC Coolant
  • Rotella T6
  • 2x10" Subs
UKShooter is offline
post #2 of 19 Old 04-05-2013, 11:23 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
It is not the head gaskets. Most likely a leak from your EGR cooler.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 19 Old 04-05-2013, 11:37 AM Thread Starter
UKShooter's Avatar
Really? Oh man that is good news! I have a Gen2 EGR delete on the way from IPR and hopefully it'll be here soon. I was planning on doing a coolant flush this weekend and oil cooler swap, should I go ahead and do that now or wait until I have the delete in hand?
  • SCT X3
  • High Idle Mod
  • STC Update
  • Blue Spring
  • CAT ELC Coolant
  • Rotella T6
  • 2x10" Subs
post #4 of 19 Old 04-05-2013, 11:41 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Wait til you have the delete in hand. Unless you want to pull it all apart twice.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 19 Old 04-05-2013, 11:58 AM Thread Starter
UKShooter's Avatar
Okay, I just called Vince and he said they are currently out of stock and it'll be Monday before it ships. Once I get it, is a leaking EGR Cooler going to affect the flush? i.e. could it be clogged and not allow coolant to flow through it and flush the system properly?
  • SCT X3
  • High Idle Mod
  • STC Update
  • Blue Spring
  • CAT ELC Coolant
  • Rotella T6
  • 2x10" Subs
post #6 of 19 Old 04-05-2013, 12:12 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Could be.......
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 19 Old 04-05-2013, 12:55 PM Thread Starter
UKShooter's Avatar
Also, I might have to go back to work (drive from KY to Cambridge OH) soon, would it be okay to drive it with it leaking like this?
  • SCT X3
  • High Idle Mod
  • STC Update
  • Blue Spring
  • CAT ELC Coolant
  • Rotella T6
  • 2x10" Subs
post #8 of 19 Old 04-05-2013, 01:00 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Bring it to me in Carrollton Ohio. I can do it for you.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 19 Old 04-05-2013, 05:36 PM
JustinOOO9's Avatar
Quoted: 553 Post(s)
Garage
you'll want to flush with 2qrts of vc-9 25$ a qrt from dealer but it cleans iron, scale and removes the silicate. I just had a blown headgasket and getting fixed this weekend.
1. you have gauges to check temp dif between engine oil temp and engine coolant temp?
2. have you run a pressure test on coolant system?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #10 of 19 Old 04-05-2013, 05:58 PM Thread Starter
UKShooter's Avatar
I do have a DashBoss to monitor everything. My delta is about 15 degrees, so I know I need to change my oil cooler. I have all of my parts ready to go I just can't start on it right now because I'm supposed to be going back to work next week.
  • SCT X3
  • High Idle Mod
  • STC Update
  • Blue Spring
  • CAT ELC Coolant
  • Rotella T6
  • 2x10" Subs
