P0266 Code on a 2003 6.0 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-04-2013, 05:32 PM Thread Starter
jake_duet's Avatar
After finally replacing my ICP sensor, we threw the truck back together and cranked it up. Ran fine for the first day or two, then one morning, (about 55-60 degrees) i started it up and let it warm up for a few minutes, then i took off out the street and had no power when i tried to take off until it got to almost 2,000 rpm, the took off like a bat outta hell, and then i had a huge miss, and now at idle it has a roughness to it, and when i take off you can hear it sputter then go. Throwing a P0266 code and im hoping i wont have to sink more money into fixing another problem. (Truck has 182,xxx miles). Any way to check see if it is a failing injector?
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
post #2 of 2 Old 04-04-2013, 05:46 PM
error code p 0266 cylinder 2 contribution/balance fault
DieselFord is offline
Tags
2003 , 6.0 , injectors , p0266 , trouble codes
