looking for a lpop - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-04-2013, 05:20 PM Thread Starter
looking for a lpop
hey guys I am having problems with my powerstroke I have 3 psi of oil pressure which is causing a no start I believe the ford dealer has the truck and is trying to tell me the motor is trashed so I am going to go get it and put a lpop in it but I cant find one on the internet thanks for any help I was also wondering how hard they are to change I have alrady done the hpop oil cooler egr delete stand pipe and dummy plugs thanks for any info
dj.oneil is offline
post #2 of 9 Old 04-04-2013, 05:44 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
Did you check your ICP and IRP?
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT Livewire Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #3 of 9 Old 04-04-2013, 06:27 PM Thread Starter
No the dealer still has it till morning the irp is new along with the hpop oil cooler egr delete stan pipes and dummie plugs is there a way to check the icp sensor
dj.oneil is offline
post #4 of 9 Old 04-04-2013, 07:47 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
Unplug the ICP sensor and it will trick the computer into setting the default 500psi (I think) and if the truck starts up then that's your problem. I had the same symptoms when my ICP went bad. Sometimes it can be a chore to trace the cause of the problem so I always try to start with the free and cheap DIY tests. I'm no expert so hopefully one of the guys with more experience will chime in. Good luck and keep us posted.
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT Livewire Tuner
post #5 of 9 Old 04-04-2013, 08:29 PM Thread Starter
ok thanks for the info I will try that and see what happens before I just start ripping the engine out and stuffing my 12 valve cummins in it
dj.oneil is offline
post #6 of 9 Old 04-05-2013, 08:45 PM Thread Starter
well I got the truck from the dealer and tried to unhook the icp and still nothing so I pushed the little tab in the filter housing and I am getting oil in there but very little so I got me the lpop from the dealer.my question is does anyone know how hard these are to change and am I going to need any special tools to do this job
dj.oneil is offline
post #7 of 9 Old 04-25-2013, 08:50 PM
Louiediesel's Avatar
Sorry didn't see this thread before, but if you still need help on what you need to do,let me know did it twice to my truck......
Louiediesel is offline
post #8 of 9 Old 04-25-2013, 09:35 PM Thread Starter
Ok thanks I will be working on replacing my lpop pump when I get home tomorrow thanks for being willing to help
dj.oneil is offline
post #9 of 9 Old 04-25-2013, 09:43 PM
sure anything you want to know about ,let me know!!!I had to do my twice because the first one the sent me was defected, so look at yours very closely, it will save you a bunch of time and work......
