03 6.0 falling on its face - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-04-2013, 06:44 AM Thread Starter
Cotton_450's Avatar
I have an 03 and it starts fine but the problem is when I hit the pedal it has no power until about 2500 rpm after that it runs just fine. Any ideas on what the problem could be guys?
Cotton_450 is offline
post #2 of 6 Old 04-05-2013, 05:54 PM
southend's Avatar
Turbo vanes sticking, map sensor hose clogged/cracked/split. Do you have a monitor?
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 6 Old 04-05-2013, 08:14 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 571 Post(s)
Garage
EBP sensor may be plugged up keep a eye on your boost, vanes may also be froze. Avoid overboosting the engine for sure.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is online now
post #4 of 6 Old 04-06-2013, 04:24 AM
southend's Avatar
Iirc, the 03 later ecm strategy, eliminates the ebp sensor. So not sure that would be an issue.
southend is offline
post #5 of 6 Old 04-08-2013, 03:45 PM Thread Starter
Cotton_450's Avatar
Ok thanks. Also to add to it when u drive the truck the waste gate opens up and won't allow it to build boost and it boils black smoke like crazy
post #6 of 6 Old 04-08-2013, 04:16 PM
southend's Avatar
Your turbo is a variable geometry turbo. Vgt, there are moveable vanes that can become stuck/corroded over time. There is no wastegate. Check what was mentioned, and expect to pull the turbo and clean it up. There are writeups and videos on youtube.
southend is offline
