6.0 mechanic's special - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-04-2013, 04:45 AM Thread Starter
burchesss's Avatar
I just bought a 04 f350 lariet crew cab 4x4 that is not running (hard starts runs a few seconds and dies). he had gotten the diagnosis of bad injectors. I am geting no codes and have 47v at the FICM. once I could look the truck over I found a freeze plug missing from the head on each side and when I crank it over oil drips from the hole on the driver side... could The oil cooler be ruptured and causing this, or should I plan on pulling the heads? any way to test w/o pulling the cooler? Thanks.
burchesss is offline
post #2 of 2 Old 04-04-2013, 04:47 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
Here is a bump for you!
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
