06 f350 issues - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-03-2013, 07:13 PM Thread Starter
06 f350 issues
Bought a new truck having all sorts of issues where do I start
First hard start cold, 10-15 sec to start, smoke till it warms up blue/white
Idles horrible no power, codes injector 8 code for both high and low circuit issues, unplugged icp no difference in starting or idling
Alt not charging as of today batt light coming on fully charged batteries and boosting off my other 6.0 to ensure good voltage while testing
Pulled injector 8 connector one pin is slightly black burnt maybe,
It seems injector 8 is done but my main question I guess is one injector enough to cause horrible start and no power condition? When truck warms up it doesn't get any better still runs the same way any help is appreciated thanks
jmccart is offline
post #2 of 4 Old 04-03-2013, 07:40 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
This is a shot in the dark but it has been shown to work (and Im sure there is guys that would argue against it) but its easy and its worth a shot, Ill bet you your trucks fot that thick old rottella 15-40 in her. Go get some Rottella t6 and a bottle of rev x or archoill do a oil change and go for a drive. My truck started up 100% better once I got that old dino oil out.
The10-15 second start up is scary, that might be the HPOP but what the heck its worth a try.
Do you have a monitor in there yet?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 4 Old 04-03-2013, 07:56 PM Thread Starter
No monitor but will be going over it with scanner this weekend, when it's warm it starts decent tho still hpop?
jmccart is offline
post #4 of 4 Old 04-04-2013, 05:29 AM
Hard start cold... I would start with the basics... load test batteries, fix charging system, check FICM.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
