cold start and coolent problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-03-2013, 03:52 PM Thread Starter
every time i start my truck cold it cranks for way too long but once my truck is warmed up it starts right up.....as for my coolant problem, i bought a new coolant reservoir and cap from ford and it keeps blowing coolant out of the reservoir and i know im not over filling it... you guys got any ideas ??
06-350 is offline
post #2 of 3 Old 04-03-2013, 05:35 PM
PHYRMN's Avatar
Looks like you have 2 problems, possibly a FICM problem, and leaky headgaskets. You need to monitor the sensors with a scangauge or torque app etc. You need to know what your FICM voltage is and what your ICP and IPR readings are with key on engine off, and after its started when cold, and when warmed up. 9 times out of 10 coolant puking is headgaskets.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 3 Old 04-04-2013, 07:59 AM
mine was puking the same way it was my oil cooler plugged. I hope its that simple for you too
dj.oneil is offline
