missing - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-02-2013, 10:35 AM Thread Starter
missing
i have an 03 f250. when in park with no load if i rev it to any rpm you can hear the engine have miss fires. this has never meant anything to me because when driving it never missed. now its starting to miss when cruising at 50 to 70 ish in overdrive. if you get into the throttle a little u can feel it every so often, if you get into it enough to down shift its fine and no miss... its slowly getting worse so id like to try n figured it out, any suggestions?
jbrogan2007 is offline
post #2 of 3 Old 04-02-2013, 03:17 PM
I had similar symptoms on my truck I just reassembled, and I had a bad injector #8. Do you have a scanner?
Lance1 is offline
post #3 of 3 Old 04-02-2013, 04:32 PM
southend's Avatar
Dead injector, you need a monitor.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
