White Smoke After Egr Delete? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-02-2013, 07:43 AM Thread Starter
I recently got an egr delete using the IPR Gen 2 delete kit, and i currently have an sct tuner with custom innovative tunes with the egr valve off. I've taken it to my mechanic and he ran gasket and injector tests already and says everything checks out and cannot figure out what the white smoke is. After I start the engine, about 1 minute after takeoff at a stoplight it starts puffing white smoke, after the engine warms up it stops, and does an extremely mild puff of white on each take off. Any advice would be appreciated, it's just plain embarrassing to be driving around town with white fumes going everywhere until the engine warms up.
Twinturbosftw is offline
post #2 of 3 Old 04-08-2013, 07:22 PM Thread Starter
Bump =\
post #3 of 3 Old 04-08-2013, 08:47 PM
Check your FICM as per the procedure you will find in this forum.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
