05 f350 no start - no codes - but cranks - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-02-2013, 06:16 AM Thread Starter
05 f350 6.0 4wd cc 70 k miles. No mods. New FICM last year.
She started the other day and I let her warm up for a few minutes, put her in reverse and she died.
WOuld not restart, cranks fine, good battery voltage, ficm at 49 volts cranking, clean fuel and filters, just no combustion.
Any clues
2005 SRW f350 Lariat CC 8ft bed, black!
Matches my 03 black turbocharged Marauder!
jupiter is offline
post #2 of 5 Old 04-03-2013, 07:37 AM
I have an 06 f250 4wd cc with 111,000 no mods and no engine issues to date. Jump in to warm her up this morning and she just cranks and cranks. I have been reading around here about the FICM. I will try to check that tonight. I have read a bunch about the HPOP system not having enough pressure and the engine not lighting off so you might wanna check that out.
Evilspyderman is offline
post #3 of 5 Old 04-03-2013, 07:53 AM
Dieselsite Barbie's Avatar
Would you possibly know your ICP and duty cycle?
Dieselsite Barbie is offline
post #4 of 5 Old 04-03-2013, 07:58 AM
Fordmanalan's Avatar
there a lot of things it could be... But first answer would be You lost your HPOP. can you throw a scanner and see what your ICP is? if you cant make over 500 ICP most likely you lost your HPOP
2006 F350, 6.0, CCSB
ARP's, Pmax, CASS 190/100's, SCT SF3 Erics tunes, Swamps 58V FICM, DRP EGR Delete, NLF Intake Pipes, Flo Pro, DRP RR, Fuel Bowl Delete, P&P heads, DRP Fuel Sump, FASS 220 571 HP 35" Toyo MT's, 20" Fuel wheels, Bushwacker's, 08 Mirrors, O8 Rear, leveled, bilsteins, AMP steps, ROYALTY CORE GRILL
571 HP 1213 lbs ft torque
PROUD OWNER OF ONE THE FEW SHOPS IN THE NORTHWEST THAT SPECIALIZE IN THE POWERSTROKE ENGINE.
DIESEL WURX
LOCATED IN SRINGFIELD OREGON
541-868-6658
Fordmanalan is offline
post #5 of 5 Old 04-03-2013, 11:11 AM Thread Starter
Thanks!
Can I get that on my Scan guage while cranking over?
jupiter is offline
