Pressure washed now won't run - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-01-2013, 11:25 PM Thread Starter
UNDERCOVER_73's Avatar
Just pressure washed my engine compartment on the 6.0 stated it up.ran like crap. Then died after 30sec, wouldn't start back up. After cranking still nothing fuel bowl fills up. Air filter got wet , connections didn't seem wet tho. Won't even run on either. Injectors aren't opening
-06 F250 SCSB 6.0 191k
TSD Super Panty Dropper
190/100s
Gt4294 Turbo
5" Exhaust
Airaid intake
Studded and Deleted.
50" Led Light Bar
4" lift 37x14s
-04 Crown Vic P71 interceptor 160k
UNDERCOVER_73 is offline
post #2 of 21 Old 04-02-2013, 12:58 AM
this is my worst fear every time i wash out my engine bay i pray that this dosnt happen to me sry for the trouble
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #3 of 21 Old 04-02-2013, 03:11 AM
6.0f250firstcar's Avatar
You most likely fried one of the sensors.
Ryan
6.0f250firstcar is offline
post #4 of 21 Old 04-02-2013, 05:57 AM
Quoted: 28 Post(s)
What year? 03-04?
If you can't get it to run on either I would say the throttle valve (connected to the intake manifold) is grounded to the closed position preventing air(and either)from going in
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #5 of 21 Old 04-02-2013, 06:56 AM Thread Starter
No i mean it will try to to tin if i spray it in there. But the injectors aren't pumping fuel in the motor. I'm thinking possibly fried the ficm, icp.
Air for senspr got wet,.would that cause three truck not to run?
190/100s
Gt4294 Turbo
5" Exhaust
Airaid intake
50" Led Light Bar
4" lift 37x14s
post #6 of 21 Old 04-02-2013, 07:03 AM
Quoted: 28 Post(s)
You need to get some readings somehow
Ficm volts ( 48 vdc)
Icp volt or pressure ( engine needs more than 500psi to run)
Ficm sync (yes no)
Most monitors will give you that info.
06 350 CCLB
Edge CTS
ARP's
Coolant filter
rentstdi is offline
post #7 of 21 Old 04-03-2013, 04:40 AM
Send a message via Yahoo to XxStr0kethisxX
Same thing happen to me about a year ago it was the ficm
With key turned if you don't hear the injectors buzzing its most likely your ficm
XxStr0kethisxX is offline
post #8 of 21 Old 04-03-2013, 05:45 AM
Term3's Avatar
Quoted: 2 Post(s)
I'd start by pulling sensor connectors and taking some canned air to blow any possible moisture out. Sure you could have got water into the FICM but that's a pretty fat gasket so you would need to be holding the water spray REAL close in order to get some inside the FICM.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #9 of 21 Old 04-03-2013, 08:04 AM
PHYRMN's Avatar
I use this on my connectors under the hood, or anwhere else where water might be an issue.
https://www.dropbox.com/s/kurhte9jiq...L._SL1500_.jpg
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #10 of 21 Old 04-03-2013, 08:07 AM Thread Starter
Thanks for coMing out man, I'm herring those filters today and replacing.the Ficm
190/100s
Gt4294 Turbo
5" Exhaust
Airaid intake
50" Led Light Bar
4" lift 37x14s
