2005 wrong diagnoses, dealer over charges beware - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-01-2013, 05:55 PM Thread Starter
rbj
Hello new to the site and powerstroke of about two months. Ok so I bought 2005 nice clean truck 210,000 , i have put 3000 on it .truck started running bad 3 miles from home then died in driveway . Got it tow to dealer they said it needed eight injectors replaced and a FICM (4500.00) I said forget I will have to wait did not have that kind of cash right now. Did not believe them so pulled it into the garage and started with changing fuel filters, and bleeding air out of fuel system . Truck started ran for 5 min and quit , pulled fuel pump from frame cleaned started it up did same thing. Dropped tank and found pickup check valve fell out . I drained tank of 6 gallons of fuel cleaned and popped check valve in and drilled small hole in at edge of check valve and pinned it so it could not fall out again . 5 gallons of fresh fuel , and filtered 6 gallons back in. Truck fired up ran great. What happen to needing 8 injectors and FICM. 58.00 for filter maintenance , and two nights worth of time. Went up to dealer and told how far they where they said sorry what the F--k.
rbj is offline
post #2 of 3 Old 04-01-2013, 07:09 PM
WEWILLE's Avatar
Just curious as to why you dropped the tank right away? Explain to me your thought process?
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #3 of 3 Old 04-02-2013, 04:26 PM Thread Starter
rbj
It just seem to be running out of fuel/ sucking air into system. I thought maybe the foot had broke off the pickup .
rbj is offline
